Quote Originally Posted by black0men View Post
help lang po.
What could be the problem of an A/T Tranny if the car jerks a little when shifting from park to drive or to reverse etc? (Whenever the tranny is shifted)
Thanks po..
Possible causes :
1.Low level automatic transmission fluid . Check the dipstick.
2.Change due ATF . When did you change your atf ? Get a white tissue paper and let a drop of your atf .If the color turn brown atf should be change. Smell the use atf if smell burnt not good change it.
