Results 21 to 29 of 29
- 52,731
February 22nd, 2019 10:29 AM #21has this car been with you for some time now, or is it a new acquisition?
if the latter,
my wild guess would be, someone adjusted the clutch. how this is related to the leak... but he over-adjusted it, so that eventually, nawala yung clutch play, resulting in a clutch that's perennially in limbo.
nice to see that your clutch issues are over so easily.Last edited by dr. d; February 22nd, 2019 at 10:42 AM.
- Jul 2018
- 22
February 22nd, 2019 12:06 PM #22been with me for half a year.
It was all me, i got a clutch repair kit for the slave cylinder then installed it myself. it worked naman nung first day, then kinagabihan kinalas ko ulit to sand off some of the uneven surface inside the slave cylinder kasi parang nag-react na yung clutch fluid. too bad for me i thought cranking the clutch pedal to remove air trapped inside the lines was sufficient, and that was after seeing the pin pushing against the fork when depressing the clutch pedal. turns out sobrang tukod pala that the fork is always engaged thus decoupling the clutch disk.
chalking that up to inexperience.
yep senyor, buti na lang. and the shifting mechanism is rock solid, my friend said it aint going out anytime soon.
on a more positive note, the learning part is a great dividend.
- 52,731
February 22nd, 2019 12:59 PM #23
- Feb 2019
- 58
April 17th, 2019 09:44 PM #24
- Feb 2019
- 58
April 18th, 2019 12:26 AM #25
- Nov 2014
- 454
May 11th, 2019 10:11 PM #26Hi, Si Erti namin me huni pag tinatapakan ko yung clutch pedal. Ani kaya issie non, gear oil, bearing?
TIA
Sent from my LG-M700 using Tapatalk
- 52,731
- Nov 2014
- 454
May 12th, 2019 09:52 AM #28
- 52,731
May 12th, 2019 09:55 AM #29the release bearing.
it's one of those parts, whose labor is considerably more expensive than the part being replaced.
the advice to me by a grizzled old mechanic,
"replace the release bearing whenever you have the transmission box opened."
fortunately, i haven't had any transmission box opened, in 2 decades...
Xiaomi E-Car
