Results 1 to 8 of 8
- Jun 2012
- 7
August 17th, 2012 03:33 PM #1Good day mga sir,
Tanong ko lang po sana kung ano yung possible na sira nung kotse ko. Hindi ko siya makambyo kahit anong gear/reverse pag naka on yung engine. Pag naka off naman yung engine pumapasok siya pag sinusubukan ko. Kaya ginagawa ko i off ko muna yung sasakyan saka ko siya i kakambyo tapos on ulit para nakapasok na siya sa gear. Have to do it everytime na kakambyo ko into any gear. Tsaka napansin ko din pala na pag naka 2nd gear ako kahit na naka full tapak sa clutch tapos pag binitawan ko yung break umaandar siya mag isa kahit di naka bitaw sa clutch, parang automatic. Pati pala nag ddrop yung idling nya ng medyo mababa pag naka gear ako kahit fully pressed ang clutch. Pati matigas din tapakan yung clutch niya unlike sa normal stock cars/sedans.
Btw yung kotse po pala 97' Toyota Corona Exsior. Automatic siya dati then cinonvert sa manual pati change engine. Manual na kasi nung nakuha ko tapos nagkaganito.
- Jul 2009
- 3,604
- Jul 2003
- 573
August 17th, 2012 04:02 PM #31. adjustment ng clutch pedal
2. pressure plate and clutch disc stucked
nilusong ba yan sa baha?
- Jun 2012
- 7
August 17th, 2012 04:12 PM #4
August 17th, 2012 06:35 PM #5
the clutch plate is probably temporarily "welded" to the pressure plate and the flywheel. if the car is far from a wall, try placing the transmission in 2 gear while the engine is off, fully depress the clutch pedal and start the engine. this usually breaks the clutch plate free.
- Jun 2012
- 7
August 18th, 2012 03:07 AM #6
- May 2012
- 33
August 18th, 2012 11:34 AM #7have the clutch check at the local gas station kung yun ang lculprit dalhin mo na lang sa roosvelt sa tapat ng PMI college may mga clutch specialist doon sa tapat ng Pantranco GI auto supply hanapin mo si Gary, mura lang doon.
- Jun 2012
- 7
August 18th, 2012 01:35 PM #8
Xiaomi E-Car
