Page 1 of 2 12 LastLast
Results 1 to 20 of 41
    Oct 2013
    To my fellow tsikoteers,
    We rebuild and repair automatic transmissions, located in imus cavite. Any transmission inquiries are welcome. Post nyo lang dito. Basta abot ng kaalaman natin, sasagutin ko ^_^. Also comments and additional information is most welcome... para makatulong.
    Jul 2006
    Saan kayo sa Imus? Any experience overhauling Benz transmissions? How long is your job warranty?
    Jul 2011
    Sir meron na ba kayo naging case na naka D ung shifter, pero since traffic tapak ng driver ung preno. Tapos meron bumanga sa likod.
    Magkakaroon po ba ng damage ang transmission?
    Oct 2013
    Quote Originally Posted by Manilablock View Post
    Case to case basis siguro sir. Kung naka apak ka sa brakes, pwedeng nag skid lang yung tires mo and there was no forced movement sa gears sa loob ng tranny. And for being naka D sya, naka engage na. masama siguro kung naka P ka. madadamage yung rod na humaharang pag naka P yung tranny ^_^
    Jan 2012
    sir sa manual transmission magkano pagawa kasi may tumutulo na. tsikot ko po corolla 2e engine 5 speed transmission.
    ilang days po pagawa?
    salamat. imus area din kasi ako
    Oct 2013
    mga 1 to 2 days sir, daan nyo na lang sa caltex bantayan.
    Oct 2013
    yes we do ^_^ for overhaul's its a years warranty, it usually takes around 4 to 5 days as long as there are no broken parts and its just the rebuilding kit we have to deal with.
    Sep 2013
    May nagawa na ba kayo sir sa CVT na transmission?
    Feb 2014
    Quote Originally Posted by shift _king View Post
    1994 Honda Accord d4 light flashing. This a surplus tranny installed one year ago. How much for diagnosis?
    Jul 2014
    *shift_king Hello Sir , seeking for recommendations. (for Toyota Revo AT 2003 Model)
    2 weeks ago, while driving, bigla nlng nag blink sa dashboard " O/D OFF " (continuously) then i noticed bigla nlng hirap umahon sa flyover ung oto while on D. Since then nawala ung usual na arangkada ng sasakyan also everytime na gagamitin after 10mins mag bblink na ung "O/D Off", Pag pa akyat I have to shift from D to 2 or L, I had it checked sa isang kakilala had a USUAL ATF changed, madumi na nga, pero after that walang improvement. Only having Problem on D, the rest - P/R/N/2/L/ is perfect.
    Would appreciate your expert opinions and recommendations. Thanks and God bless
    Jul 2014
    Nov 2014
    Quote Originally Posted by Nad0711 View Post
    Ano na balita d2 sir?
    Jul 2011
    Up po.. Makikibalita din po..
    Jun 2015
    Hi good am. Newbie lang po. Check ko lang po kung ano kaya problem ng honda civic lxi automatic 99 ko. Matagal magshift sa 3rd gear at hirap sa uphill roads and overtake. Thank you. Cavite area po ako.
    Mar 2016
    Sir, san shop nyo sa imus? Problema ko sa Sportivo 2010 AT nawawalan ng batak. napalitan na sedimentor, atf (dialysis), fuel pump, newly changed oil and filter (changed every 5kms). Transmission na lang di pa nache-check Sir. Gusto ko sana patingnan sa inyo since the subject line says you're a Specialist with regards sa automatic transmission.
    Jan 2017
    Hi, just wanna ask if what problem nung spacegear ko na subic, diesel, automatic transmission. Napansin ko kc na hindi pala lumilipat sa overdrive ung tranny ko nung naitakbo ko cya sa express way, 90kph na but still nasa 3000rpm p din cya. Note: di gumagana ung speedometer ko, gps lng gamit ko pang monitor sa speed ko. Anu kaya possible prblem nito?
    May 2011
    Quote Originally Posted by -IronHide- View Post
    You are missing one of the enable criteria:
    Vehicle speed signal. Start from there
    Jan 2017
    ok, will try to fix muna ung spedometer ko then will give you update guys, thanks!
    Feb 2017
    Hi,
    Ano contact number nyo po. May transmission issue po sa Fiesta 1.6 S 2011. Reverse problem po. I need help
    May shop po ba kayo? I'm from Imus, Cavite po. Thanks
    Pirate man
    Mar 2017
    Sir naka bili ako nissan Micra 2000 1.0 16v automatic nag jejerk pag nag papalit ng gear. Sabi ng mekaniko transmission na daw sabi 2nd opinion ko sabi engine mount. Kung possible transmission sya Sir meron ba tyo pyesa nun dito?
    We rebuild and repair automatic transmissions, located in imus cavite. Any transmission inquiries are welcome. Post nyo lang dito. Basta abot ng kaalaman natin, sasagutin ko ^_^. Also comments and additional information is most welcome... para makatulong.[/QUOTE]
Automatic Transmission Specialist in  Imus Cavite
