Results 11 to 20 of 41
- Feb 2014
- 2
February 21st, 2014 12:29 PM #11
- Jul 2014
- 5
July 28th, 2014 02:39 AM #12*shift_king Hello Sir , seeking for recommendations. (for Toyota Revo AT 2003 Model)
2 weeks ago, while driving, bigla nlng nag blink sa dashboard " O/D OFF " (continuously) then i noticed bigla nlng hirap umahon sa flyover ung oto while on D. Since then nawala ung usual na arangkada ng sasakyan also everytime na gagamitin after 10mins mag bblink na ung "O/D Off", Pag pa akyat I have to shift from D to 2 or L, I had it checked sa isang kakilala had a USUAL ATF changed, madumi na nga, pero after that walang improvement. Only having Problem on D, the rest - P/R/N/2/L/ is perfect.
Would appreciate your expert opinions and recommendations. Thanks and God bless
- Jul 2014
- 5
July 28th, 2014 03:38 PM #13*shift_king Hello Sir , seeking for recommendations. (for Toyota Revo AT 2003 Model)
- Jul 2011
- 10
- Jun 2015
- 3
June 12th, 2015 10:03 AM #16Hi good am. Newbie lang po. Check ko lang po kung ano kaya problem ng honda civic lxi automatic 99 ko. Matagal magshift sa 3rd gear at hirap sa uphill roads and overtake. Thank you. Cavite area po ako.
- Mar 2016
- 2
March 19th, 2016 10:59 PM #17Sir, san shop nyo sa imus? Problema ko sa Sportivo 2010 AT nawawalan ng batak. napalitan na sedimentor, atf (dialysis), fuel pump, newly changed oil and filter (changed every 5kms). Transmission na lang di pa nache-check Sir. Gusto ko sana patingnan sa inyo since the subject line says you're a Specialist with regards sa automatic transmission.
- Jan 2017
- 3
January 4th, 2017 09:38 AM #18Hi, just wanna ask if what problem nung spacegear ko na subic, diesel, automatic transmission. Napansin ko kc na hindi pala lumilipat sa overdrive ung tranny ko nung naitakbo ko cya sa express way, 90kph na but still nasa 3000rpm p din cya. Note: di gumagana ung speedometer ko, gps lng gamit ko pang monitor sa speed ko. Anu kaya possible prblem nito?
- May 2011
- 481
January 4th, 2017 06:11 PM #19
- Jan 2017
- 3
January 4th, 2017 09:21 PM #20ok, will try to fix muna ung spedometer ko then will give you update guys, thanks!
Maraming Salamat :)
