Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
    Feb 2014
    Quote Originally Posted by shift _king View Post
    To my fellow tsikoteers,
    We rebuild and repair automatic transmissions, located in imus cavite. Any transmission inquiries are welcome. Post nyo lang dito. Basta abot ng kaalaman natin, sasagutin ko ^_^. Also comments and additional information is most welcome... para makatulong.
    1994 Honda Accord d4 light flashing. This a surplus tranny installed one year ago. How much for diagnosis?
    Jul 2014
    *shift_king Hello Sir , seeking for recommendations. (for Toyota Revo AT 2003 Model)
    2 weeks ago, while driving, bigla nlng nag blink sa dashboard " O/D OFF " (continuously) then i noticed bigla nlng hirap umahon sa flyover ung oto while on D. Since then nawala ung usual na arangkada ng sasakyan also everytime na gagamitin after 10mins mag bblink na ung "O/D Off", Pag pa akyat I have to shift from D to 2 or L, I had it checked sa isang kakilala had a USUAL ATF changed, madumi na nga, pero after that walang improvement. Only having Problem on D, the rest - P/R/N/2/L/ is perfect.
    Would appreciate your expert opinions and recommendations. Thanks and God bless
    Jul 2014
    Nov 2014
    Quote Originally Posted by Nad0711 View Post
    Ano na balita d2 sir?
    Jul 2011
    Up po.. Makikibalita din po..
    Jun 2015
    Hi good am. Newbie lang po. Check ko lang po kung ano kaya problem ng honda civic lxi automatic 99 ko. Matagal magshift sa 3rd gear at hirap sa uphill roads and overtake. Thank you. Cavite area po ako.
    Mar 2016
    Sir, san shop nyo sa imus? Problema ko sa Sportivo 2010 AT nawawalan ng batak. napalitan na sedimentor, atf (dialysis), fuel pump, newly changed oil and filter (changed every 5kms). Transmission na lang di pa nache-check Sir. Gusto ko sana patingnan sa inyo since the subject line says you're a Specialist with regards sa automatic transmission.
    Jan 2017
    Hi, just wanna ask if what problem nung spacegear ko na subic, diesel, automatic transmission. Napansin ko kc na hindi pala lumilipat sa overdrive ung tranny ko nung naitakbo ko cya sa express way, 90kph na but still nasa 3000rpm p din cya. Note: di gumagana ung speedometer ko, gps lng gamit ko pang monitor sa speed ko. Anu kaya possible prblem nito?
    May 2011
    Quote Originally Posted by -IronHide- View Post
    You are missing one of the enable criteria:
    Vehicle speed signal. Start from there
    Jan 2017
    ok, will try to fix muna ung spedometer ko then will give you update guys, thanks!
Automatic Transmission Specialist in  Imus Cavite
