Results 431 to 439 of 439
- Aug 2019
- 19
August 28th, 2019 03:13 PM #431Thank ypu for the suggestions.. ganyan na nga sigero gagawin ko ... i am from marikina any honda specialists you know nesr our place?
- Aug 2019
- 19
August 28th, 2019 06:17 PM #432
- Aug 2019
- 19
- Aug 2019
- 15
August 30th, 2019 06:41 PM #434Hello mga ka tsikot,
So i bought a second hand 2008 Toyota Fortuner which has a 161K mileage on it. Replaced transmission fluid, timing belt, cleaned brake pads, and changed oil. Performed test drive and the Low gear doesn't engage as in hindi nag-eengine brake when in downhill. Mahina rin sipa ng 2nd Gear. Had to rev engine naman kapag may uphill kapag kaka on lang ng kotse. So as concerned owner, had to bring it up to a trusted mechanic which they then scanned and found out the following codes/issues:
- P2200 NOx Sensor Circuit Bank 1 Read more at: P22 NOx Sensor Circuit Bank 1 Copyright OBD-Codes.com
- P0722 Output Speed Sensor No Signal Read more at: P 722 Output Speed Sensor No Signal Copyright OBD-Codes.com
- P1801
- P1806
- P0504
Any suggestion / ideas mga ka tsikot for next step ?
- Aug 2017
- 319
August 30th, 2019 06:58 PM #435
- 52,731
August 30th, 2019 11:42 PM #436
- Aug 2019
- 15
August 31st, 2019 07:59 AM #437
- 52,731
August 31st, 2019 09:24 AM #438replacement sensors (replacement parts) are manufactured by "someone else", the reputation and/or quality of which might be suspect.
not that all replacement brand parts are fakes or of poor quality, but "branded or Original Equipment Manufacturer (oem) are believed to be of higher quality". they are perceived to last longer and function more reliably.
- Aug 2017
- 319
August 31st, 2019 09:30 AM #439I bought replacement bank1 O2 Sensor for my G4... 3x from 3 different sellers... Did not work.
Since they're also expensive, try cleaning it out with an electronic cleaner... Like soak it with the stuff... Install back... And hold your breath. If it doesn't work, it's really busted. If it works, it will fail later... But now you're sure that the sensor is busted.
Oh, don't forget to put anti-seize on the threads or you'll be sorry...
Xiaomi E-Car
