You should be thankful, it means your transmission's not leaking.
ATF is not "consumed" in the same way that engine oil is, where a small amount invariably reaches the combustion chamber and burned off. On well-maintained engines, this is minimized but on others, the amount of oil burned is significant, causing visible smoke in the exhaust.
