Is it normal na mararamdaman mo ang shifting ng automatic transmission na parang mahinang kadyot. Meron kapag madiin ang tapak sa gas at mararamdaman mo ang pagchange shift, pero pag light lang sa gas wala naman. Car is honda 96.
Ganun din sa aking Honda, parang hindi swabe pagshift ng gears. Normal lang yan.
on some cars maganda shifting ng automatic, on some you can feel the shifting as long as hindi grabe naman.
shift shock ata tawag dyan. Its normal. Just regularly change your ATF fluid.
Un civic ko jerky din. Pero I just noticed that lately. Dati smooth shifting naman. No improvement seen although i replaced the old A/T fluid. Balak ko na ngang patingnan kay speedyfix.
Normal lang ba sa A/T yung mag down shift siya pag uphill? Tsaka umiingay ang makina habang nagda downshift siya.
pasingit na lang ng topic. sensya na ha...
may question lang ako about an ABS warning light that intermittently going on and off, what does that mean? Can somebody enlighten me? Tnx.
i was about to post this topic... mine is a honda esi a/t. how do you guys maintain atf fluid?do you know a thread here where i can find tips on adding and checking all fluids?brake,atf,etc.. specially for a/t
thanks in advance...
your esi tranny has a dipstick naman. you can check the quality of the fluid and the level there.
