Quote Originally Posted by jlaw888 View Post
i also am in this predicament. bale, yung previous owner is i keep in touch pa naman. and he even told me nga na for 5k e sya na din magaayos ng transfer to my name.
so how do i go about it po? nasa akin na ang orig OR/CR etc..ayoko namang ibigay pa to sa kanya.
gusto ko palakad na din sa kanya at 5k. so eto lang ba bibigay ko muna sa kanya?:
name
age
address
civil status
as in no papers involved? how about yung sa chattel?
Is your unit under chattel mortgage?...so under financing na acquire ng 1st owner yun unit?...If it's the case you have to cancel the chattel mortgage first where this is executed (usually indicated in the mortgage, sa registry of deeds) if it's canceled already then you may apply for the PNP clearance, after this then LTO office where the CR is registered...just be sure your deed of sales and ID's of vendor and vendee plus CTPL are in place.
For 5K that's way to much to have him process your documents, if I were you I'd personally run the procedure, these are legal documents and I would not want to trust a stranger handling this. HTH and good luck.
