Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 545
    655db? Ano iyan, daig pa yung mga exotics at muscle cars sa tunog ng exhaust. Looks like another money making b.s. at the expense of the motoring public.
    daig pa nga daw a-bomb bro e
    Nuclear explosions are amongst loudest phenomena on Earth. Their loudness ranges roughly from 240 dB to over 280 dB. ... Decibel meters set 250 feet away from test sites peaked at 210 decibels. The sound alone is enough to kill a human being, so if the bomb doesn't kill you, the noise will.
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    Correct me if I am wrong, pero diba as long as yung LTO Office kung san ka magrenew is hindi pa "MVIC required", pwede pa yung dating method?
    Ang nangyari lang sa Norte, Region ng Pampanga, isang MVIC pa lang ang active, lahat ng LTO sa Region required na MVIC ginawa.
    This is per my understanding.
    Regarding dun sa checklist na sasagutan ng may-ari or driver, well. nakalagay naman please check and confirm lang. Hindi niya sinabi please check one only. hehe! So kung AWD pwede mo check front drive and rear drive.
    EDIT: Yung item # 6 sa checklist na "Slip", pertaining ba ito sa LSD (Limited Slip Differential)? or something else?
    Jan 2008
    Quote Originally Posted by 17Sphynx17 View Post
    looks like its the limited slip differential.. but what do you expect from these buffoons? slip lang nilagay eh ano yan nip slip? half slip?
    Aug 2004
    Daig pa ang nuke kamo (240 to 280 dB+).
    Optional pa naman ito diba? Bilib ako doon sa mga nagpa MVIS agad. Para tayo guinea pigs for learning curve nung mga tauhan at sistema.
    Meron na ba sa Pasig? Mga kasamahan ko the usual emission test lang sinubmit sa LTO sa Ynares naka rehistro na sila.
    akala ko required na bro
    not sure
    Nov 2019
    I am not surprised with this new MVIS inspection scheme.
    Dumaan ako sa ganitong inspection last year, although ako yung nag drive at dumaan dun sa mga wavy platform to test the pang ilalim.
    Ngayon ko lang nalaman, optional pa pala yun last year?
    Mataas kasi pila sa pinakamalapit naming inspection center, resulta is dun ako sa LTO inspection center mismo nagpa inspect with the same equipment for MVIS inspection.
    not sure
    Yes bro dalawa officemates ko naka rehistro na doon, magic emission lang required pa din.
    “European commission standards” oh yeah!
    sounds chock-full of legal loopholes.
    yung #1 lang yata ang siguradong na-i-intindihan at nasasagot nang may buong katotohanan at pagkaka-intindi.
    as to #7... can i just stay inside the car during the testing process?
    and how many ordinary car owners can get a 100% correct in the set of 1-8 questions at the bottom?
    Aug 2004
    #4: Pwede both?
    even the best testing equipment has to be calibrated before use, and checked and re-calibrated regularly..
    how is LTO attesting to this maintenance schedule?
    "who's going to check the checkers?"
    Sep 2010
    Kasama pala ang speedometer test? Paano yung mga nag upgrade ng gulong (eg. OEM size is 15's, upgrade to 17's or 18s) at affected yung speedometer reading? Kailangan mag back to stock para pumasa at maging accurate yung reading? Hehe
    Yung iba ata sir para may mai-vlog. Check Youtube, dami na nag v-vlog ng experience nila dito hehe.
    Jul 2013
    just wondering, anyone here who has sent their car for inspection?
    sana lang pag initan yun mga talagang di road worthy
    sana umabot ako sa august or sept
    did i read before, that they are not prioritizing the PUJs?
    ... that they will target the private cars first?
    ... strange decision...
    Politicians don’t want to piss off voters who mostly use public transport. They don’t give a sh&t to taxpayers. They want taxpayers to pay more fees and duties.
    Jan 2008
    May sagot na yung QWIk.. ang bilis.. sinisiraan daw sila..
    In my opinion, a bmw Z4 clocking 7k kms should pass that with no issue.. bagong bago pa yan eh.. although hindi imposible na may problema.. but low probability na meron.. so paano na yung mga basic cars like auv, mpv na common car ng pinoy using replacement parts? Usually yung bendix na brake pad iba ang kapit compared sa Original spec brake pads.. deviation agad yan
    Jan 2008
    “Whosoever holds this hammer, if they be worthy, shall possess the power of Thor.”
[AI] Here's what they'll check during MVIS inspection
