Results 51 to 60 of 538
- Jan 2008
- 4,726
January 21st, 2021 07:51 PM #51need daw mag test with both tire roller pag 4wd or AWD vehicle..
sa mga may stability control, dapat naka turn off yan kasi iisipin ng computer na dumudulas ka so baka mag apply yan ng electronic brake..
pero di ba pag may ABS ka, mag error naman yan kasi ma detect nya na 2 wheels lang nag roll? naalala ko dati yung mazda 323 ko na may ABS, na ilaw yung ABS light pag umandar na naka angat yung gulong
- Jan 2007
- 2,234
January 21st, 2021 08:03 PM #52Pag AWD yung axle that's not being tested kelangan nakapatong din sa rollers. Problema yung machine ng MVIC doesn't have adjustable rollers like pang dyno, so at best they'll need to use those portable ones na parang dollies.
Check out this picture.
The way the rollers are, there's no way to allow the non-tested axle to freewheel.
This is how AWD vehicles should be tested:
January 21st, 2021 08:11 PM #53
yan na nga bro, di sila ready.
im sure si assistant taga lista lang andun at chief.mechanic nakatambay lang sa booth
baka may eskena pa na, "sir di road worthy sasakyan nyo, kasi yun oem nyan may ducktail. pakabit muna kayo ducktail para ma approve kayo" [emoji28][emoji28]
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
- Jan 2008
- 4,726
January 21st, 2021 08:25 PM #54
- May 2014
- 1,318
January 21st, 2021 08:30 PM #55
- Jan 2007
- 2,234
January 21st, 2021 08:36 PM #56Found this re: LC failed sound test
LANDCRUISER VX 2017 na nagkakahalaga ng... - CAMPI Clean Air Movement of the Philippines, Inc. | Facebook
655dB! Labo naman that is obviously equipment malfunction, otherwise patay na silang lahat dun sa loob ng MVIC testing center. Hindi na dapat pinaabot yun sa papel and immediate re-test na.
- May 2014
- 1,318
January 21st, 2021 08:42 PM #57Nice getting the cleaner copy of the report.
Wow! 600+ db. Hindi kaya manual encoding ito onto the report na mag "auto flag" on that database if less than or greater than ng baseline siya to indicate the pass or fail then?
"Nuclear explosions are amongst loudest phenomena on Earth. Their loudness ranges roughly from 240 dB to over 280 dB. Only the big volcanic eruptions are louder. Explosion of the biggest bomb ever tried was heard at a distance of about 1000 km." (from Google search)
Duda naman ako na "kaya" ng meter nila sumukat ng 600+ db for no reason na any rational testing would never reach.
January 21st, 2021 08:53 PM #58
Walang gamot sa katangahan or kabobohan!
- Jan 2007
- 2,234
January 21st, 2021 08:59 PM #59Actually may nabasa ako before na parang the upper limit to "sound" on Earth (1 atmosphere) is about 194dB. Any higher and it's not sound anymore and becomes a shock/blast wave.
An Upper Limit to Sound? – Wayne Staab
January 21st, 2021 09:36 PM #60
Hinde pa nagsalita si deakin about dito? Chup-chup boy ni kingkong tugade yun eh.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
