Results 71 to 80 of 538
- 52,731
January 22nd, 2021 10:55 AM #71
January 22nd, 2021 12:03 PM #72
- Jan 2008
- 4,726
January 22nd, 2021 12:14 PM #73May sagot na yung QWIk.. ang bilis.. sinisiraan daw sila..
In my opinion, a bmw Z4 clocking 7k kms should pass that with no issue.. bagong bago pa yan eh.. although hindi imposible na may problema.. but low probability na meron.. so paano na yung mga basic cars like auv, mpv na common car ng pinoy using replacement parts? Usually yung bendix na brake pad iba ang kapit compared sa Original spec brake pads.. deviation agad yan
- Sep 2010
- 290
January 22nd, 2021 01:28 PM #74Kasama pala ang speedometer test? Paano yung mga nag upgrade ng gulong (eg. OEM size is 15's, upgrade to 17's or 18s) at affected yung speedometer reading? Kailangan mag back to stock para pumasa at maging accurate yung reading? Hehe
Yung iba ata sir para may mai-vlog. Check Youtube, dami na nag v-vlog ng experience nila dito hehe.
- Jul 2013
- 2,450
January 22nd, 2021 01:40 PM #75I'd rather have incremental improvements sa MVIS than very ambitious leaps tapos kulang sa expertise ang checkers.
- Jan 2008
- 4,726
January 22nd, 2021 02:19 PM #76
- 4,313
January 22nd, 2021 02:41 PM #77655db? Ano iyan, daig pa yung mga exotics at muscle cars sa tunog ng exhaust. Looks like another money making b.s. at the expense of the motoring public.
- Jan 2007
- 2,231
January 22nd, 2021 02:49 PM #78Malaki naman ata tolerance nung test sa speedo error. Yung dun sa LC200 parang +10% ata? That's much bigger than going up one size sa aspect ratio ng tire which usually changes the reading by 3% (i.e. 265/65R18 is 3% more circumference/diameter than 265/60R18).
From what I know about the MoT and Shaken test ang importante lang wag mag under-read, kasi baka mangyari naka indicate sa speedo 100kmh pero overspeeding ka na. Most car speedos overread by default (usually around 10%) kaya one size bigger tire should be safe pa.
January 22nd, 2021 02:50 PM #79
daig pa nga daw a-bomb bro e
Nuclear explosions are amongst loudest phenomena on Earth. Their loudness ranges roughly from 240 dB to over 280 dB. ... Decibel meters set 250 feet away from test sites peaked at 210 decibels. The sound alone is enough to kill a human being, so if the bomb doesn't kill you, the noise will.
- May 2014
- 1,318
January 22nd, 2021 02:54 PM #80Correct me if I am wrong, pero diba as long as yung LTO Office kung san ka magrenew is hindi pa "MVIC required", pwede pa yung dating method?
Ang nangyari lang sa Norte, Region ng Pampanga, isang MVIC pa lang ang active, lahat ng LTO sa Region required na MVIC ginawa.
This is per my understanding.
Regarding dun sa checklist na sasagutan ng may-ari or driver, well. nakalagay naman please check and confirm lang. Hindi niya sinabi please check one only. hehe! So kung AWD pwede mo check front drive and rear drive.
EDIT: Yung item # 6 sa checklist na "Slip", pertaining ba ito sa LSD (Limited Slip Differential)? or something else?
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
