Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 60
    #31
    up...........
    #32
    no. going straight, stay in middle. going left, dapat bago ka pa lumiko, pwesto ka na agad sa left kasi pag hindi, swerving ka nyan paps...
    #33
    Quote Originally Posted by pobreparin View Post
    +1
    take note that learning to drive not only means learning how to make the vehicle move. You should also learn driving etiquette, what's the meaning of the different traffic and road signs, defensive driving, car maintenance,basic car repair....
    At ang pinaka-importante sa lahat...Being a licensed driver does not only gives you the privilege to drive a motor vehicle but it is also undertaking a RESPONSIBILITY. This means you cause damage to life or property while in control of a vehicle, you pay for that damage. If there is any doubt as to who has the fault, you have to present your case to a traffic court.
    #34
    Quote Originally Posted by jspydrej View Post
    *ChevyChaser
    sir advice naman din po halimbawa 4 lane po siya tapos may stop light then nasa left most ako bale didiretso ako e merong left left turn mali po ba na nasa left most ako?thanks
    Normally, road segregation lanes are painted with directional arrows about 10 to 15 meters before any intersection. In a 2 lane road (where a left tun is allowed, the both lanes can be used by vehicles turning or going straight. Left lane turns left, right lane turns right. On a 3 lane road ( where left turn is allowed ), the middle lane is absolute going straight. Right lane for vehicles going straight or turning right, left lane is turning left.
    On a 4 lane road (where left turn is allowed), the left most lane (aka inner lane) is for vehicles turning left only, the two middle lane is for vehicles going straight and the right most lane (aka outer lane ) is for right turning vehicles only.
    As I do, I will advice that before you start your trip, PLAN AHEAD. Think: "WHERE WILL I PASS?" Assess the situation, If you're caught in a heavy traffic, for sure it's heavy traffic every where. Let's say you are in EDSA CUBAO going to MAKATI via BUENDIA AVE. and traffic is slow moving. Will you stay on the inner left lane. Of course not. It would be wiser to stay in the middle lanes. when you get to just past Guadalupe, you change to the next right lane. Always use your signal light whenever changing lanes. In the US, changing lanes without a signal light is illegal and carries a heavy fine. This way you do not inconvenience other drivers around you or yourself.
    Our roads are painted/marked by signs and as a licensed driver, it is your responsibility to know all these markings.
    You will notice a white line along the curb of the road, this does not say "pedestrians keep off" or "this is the width of the road" rather the white line means " ABSOLUTELY NO STOPPING OR PARKING ALONG THE CURB ". In Singapore, the equivalent of this line is a zig-zag line painter along the curb of the road.
    #35
    ganun din po ba pag right turn naman po? pwesto ka na agad sa right bago ka pa lumiko.
    #36
    Of course. You should always do this whether turning left or right. Otherwise, you will not only inconvenience yourself, those behind you but also those going the other way as you may make your turn too wide.
    Also, keep your vehicle in your lane. If you start your turn on the right outer lane then keep to the right outer lane. If your on the left, you shoould also end up on the left. Kung nasa midle ka, then end your turn in the middle. DO NOT CUT ACROSS in front of others.
    #37
    ano dude? ok na driving mo nowadays?
    Jun 2007
    #38
    pinakamagandang advice pag nagamamaneho pag liliko o mag change ng lanes wag kalimutan iturn on yung signal light at matuto mapagbigay sa kapwa motorista wag ka swapang.
    Oct 2007
    #39
    Quote Originally Posted by dieselNUBI View Post
    i not sure if this is true but the tsikoteers here could verify it for themselves.
    you'll only learn how to drive kapag naka bangga kana/ or pag naka sagi kana.
    after that. you'll learn from mistakes.
    Yan ay kwentong barbero!
    You start learning to drive by reading a driving handbook.
    First step is buy or borrow a good driving handbook.
    Hindi puede na kailangan mag crash muna airplane bago matawag na piloto ang
    gumagamit nito.
    Oct 2007
    #40
    Quote Originally Posted by ChevyChaser View Post
    This one is very good. Plan ahead and drive your plan.
advice naman po newbie po ako sa pagdridrive ng kotse.
