Results 1 to 8 of 8
    Jan 2011
    Normal lang po ba na after aircon cleaning eh magdagdag ng tubig sa radiator? Napansin ko po kasi na nabawasan tubig ko sa radiator at sa reserver niya. Tia
    Quote Originally Posted by 105.1 crossover View Post
    there's no connection between the aircon and the radiator.
    baka nagkataon lang..
    Oct 2014
    Nataas ho ba ung temp nyo like above the average?
    Nagdadagdag po ba kayo lagi ng tubig everytime ginagamit nyo auto?
    What about after using your vehicle and cool-it down after a few minutes tas when checking e bawas na po tubig?
    If wala pong leak ung hose nyo either tl or from your radiator, baka kailangan po i-flush or ipa-sondo na ung radiator...
    Nagamit ho ba kayo ng coolant?e ung tubig na galing gripo po?un po kasi tubig galing gripo e nagiiwan po ng kalawang...
    Normally, hindi po dapat magbabawas ung tubig nyo sa radiator... Ung sa reservior, dapat po konti lng ang mababawasan...
    Unless me leak or barado po ang radiator nyo..
    wala syang direct link.
    observe mo muna.... pag naulit, observe for leaks.
    Jan 2011
    Nakausap ko na po yung aircon tech na gumawa, apparently may, tinnagal na hose connected sa radiator upon aircon cleaning. So far after ko magdagdag ok na siya ngayon. Back to normal na level ng reservoir ko at radiator.
    Mar 2005
    Use only coolant and distilled water sa cooling system. Aluminum ang fins ng radiator ng Camry.
    The A/C system heater (if equipped) uses heat from the cooling system loop if activated. If the cooling system bypass hose to the heating core was cleaned or touched, it can result in some coolant loss during such a process.
    Jan 2011
    Exactly sir. Eto din sabi nung technician.
Water level sa radiator went low.....
