Results 1 to 8 of 8
- Jan 2011
- 47
January 4th, 2015 01:27 PM #1Normal lang po ba na after aircon cleaning eh magdagdag ng tubig sa radiator? Napansin ko po kasi na nabawasan tubig ko sa radiator at sa reserver niya. Tia
- 52,698
January 5th, 2015 12:41 AM #2
- Oct 2014
- 5
January 5th, 2015 01:15 AM #3Nataas ho ba ung temp nyo like above the average?
Nagdadagdag po ba kayo lagi ng tubig everytime ginagamit nyo auto?
What about after using your vehicle and cool-it down after a few minutes tas when checking e bawas na po tubig?
If wala pong leak ung hose nyo either tl or from your radiator, baka kailangan po i-flush or ipa-sondo na ung radiator...
Nagamit ho ba kayo ng coolant?e ung tubig na galing gripo po?un po kasi tubig galing gripo e nagiiwan po ng kalawang...
Normally, hindi po dapat magbabawas ung tubig nyo sa radiator... Ung sa reservior, dapat po konti lng ang mababawasan...
Unless me leak or barado po ang radiator nyo..
January 5th, 2015 09:42 AM #4
wala syang direct link.
observe mo muna.... pag naulit, observe for leaks.
- Jan 2011
- 47
January 6th, 2015 05:16 PM #5Nakausap ko na po yung aircon tech na gumawa, apparently may, tinnagal na hose connected sa radiator upon aircon cleaning. So far after ko magdagdag ok na siya ngayon. Back to normal na level ng reservoir ko at radiator.
January 6th, 2015 05:58 PM #6
Use only coolant and distilled water sa cooling system. Aluminum ang fins ng radiator ng Camry.
January 6th, 2015 06:24 PM #7
The A/C system heater (if equipped) uses heat from the cooling system loop if activated. If the cooling system bypass hose to the heating core was cleaned or touched, it can result in some coolant loss during such a process.
- Jan 2011
- 47
It's looking like Shopee / Lazada / AliExpress have a long list of available parts for various...
2024 Manila International Auto Show APRIL 4-7,...
