Results 1 to 10 of 11
- Nov 2009
- 3,507
January 18th, 2019 03:44 PM #2Possible or one of the rectifier is busted. Hook up a volt-meter to check voltage drop.
May whining sound ba as you rev or the steering becomes hard?
January 18th, 2019 03:50 PM #3
- Nov 2009
- 3,507
January 18th, 2019 04:01 PM #4Hard steering(EPS) and whining noise is a tell-tale sign of busted alternator/ rectifier.
For 2nd issue, could be a tampered fan wiring. If not tampered, a shorted thermo switch/ AC senser.
January 18th, 2019 04:05 PM #5
- Nov 2009
- 3,507
January 18th, 2019 04:10 PM #6iirc coolant sensor and thermo switch are separate bung screwed on different location in the engine.
January 18th, 2019 04:28 PM #7
- Nov 2009
- 3,507
January 18th, 2019 04:44 PM #8Try ko check pero makikita rin yan ng electrician na titingin ng alternator mo. Same lang nman ng 2nz yang 1nz.
Yun wire ng fan sa relay nkkabit so yung primary ng relay i-trace mo ,o kung saan tampered malamang sa acc-on position kinabit.
- Nov 2009
- 3,507
- Jun 2005
- 3,774
January 18th, 2019 10:09 PM #10Clean the Throttle body and MAF sensor. That should help, of not fix it.
Sent from my MI MAX 2 using Tapatalk
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
