View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
- Aug 2014
- 73
August 27th, 2014 01:33 AM #9011sir nakakita na ako ng ganon sa vios ng kapit bahay namin kaso napansin ko pangit ang quality ng sounds at mahina sya. gusto ko sana ung kagaya sa G varriant pwede po ba iyon ganon sa E salamat po
August 28th, 2014 02:55 PM #9012
Mga Sir, patulong naman po. My gen2.5 31K odo, last PMS was on its 30K kms is having a high rev on cold start. Umaabot po ng 1900rpm, before is only around 1,400rpm usually. Normal lang po ba yung 1,900rpm? I was thinking di po kaya sa Air Filter ko kasi di pa ako nagpalit since day1 although mejo malinis pa naman kasi so every PMS binubugahan lang ng hangin. Or probably any other reason? TIA for your help.
August 28th, 2014 04:26 PM #9013
although ours is a 2006 E, never seen it start cold at less than 1500rpm. ever since we had it, around 2krpm talaga siya on early mornings.
August 28th, 2014 11:21 PM #9014
- Jan 2014
- 158
August 30th, 2014 10:38 PM #9015Guys need your help
I was driving from nueva ecija going to manila yesterday , it was raining that time and medyo baha yung daan pero mga 1 inch thich lang ung tipong tatalsik yung tubig pag dinaanan mo , then bandang papuntang TPLEX i noticed on my dashboard a RED BATTERY INDICATOR LIGHT shows up , it shows up twice 1 min duration each then after that it disappear , so i got nervous , i turn off the ac my sounds and the wiper as well , then i drove slowly and i stopped the car after 10-20mins after i saw that indicator light so pinark ko sa tabi i turn off the engine and checked the hood , wala namang usok or something wala ding nag sspark or something so ipinahinga ko mga 20-30 mins then i turned on the engine again and drive , hindi naman ako nahirapan mag start ng kotse at nakauwi pako hanggang manila at hindi narin nag show up yung indicator light ng battery while im driving . Ano kaya nag caused non? san ko kaya pwede ipa check ang battery ko? yung trusted at hindi ako lolokohin? could you recommend some shops guys!
Im located BF Homes Paranaque malapit lang ako sa Alabang Town Center ,
My ride is Toyota Vios 1.5G 2004 model Automatic got 172,200 KMS in my odo
Battery was replaced nung january lang this year kaya medyo concern ako dahil matic ang ride ko at ayaw ko magkaproblem when im on a long drive .
ALso tanong ko lang ok ba magpa engine wash or engine detailing nalang sa big berts? kasi engine wash cost 300 sa customers cradle yung engine detailing naman cost 1k sa bigbert bf homes, ano ba difference nila bukod sa price?
please help me guys thanks!
- 52,734
August 30th, 2014 10:51 PM #9016red battery indicator light during floods, can be explained by belt slippage.
kapag baha, natatalsikan ng tubig ang fanbelt. dumudulas tuloy sa alternator. when the belt slips, the alternator loses rpm, and electricity generation is lost. this causes your warning light to brighten up.. but once the water boils off (due to friction and heat), slippage disappears and your warning light disappears also.
it may also be a sign that your belt needs tightening... so check it and doh it!
- Jan 2014
- 158
August 31st, 2014 03:37 PM #9017
- Aug 2014
- 73
September 2nd, 2014 08:15 PM #9018good evening mga sir.. asko lang sana kung sino na dito nagpalinis ng aircon sa labas? going to 25 km na kasi yung sa amin . sabi kasi sa casa pag daw 25km need na linisin ang aircon hindi po namin kaya ang presyo ng casa nag tanong tanong kami sa labas meron 4.5k at meron din 4k. tinanong ko yung proseso ng linis nila yung iba kalas buong dashboard yung iba hindi daw lahat kasi daw maraming pwede mangyari pag kalas lahat ng dashboard yung iba dapat daw talaga kalas lahat.. mga sir advice naman po please chaka need n ba talaga kasi malapit na kami mag 25km pero ang lamig lamig padin kht puno po kami salamat po wait ko po mga advice nyo po salamat
September 2nd, 2014 08:30 PM #9019
- 52,734
September 2nd, 2014 08:36 PM #9020if my aircon ain't broke, i wouldn't have it serviced. even after 25K. my (probably controversial) belief is, kung masisira ang aircon, masisira 'yan kahit na ano ang gawin mo.. the exception is, if your aircon is so dirty, no air can pass thru anymore.
iipunin ko na lang ang gagastusin sana, para sa pag tunay na hindi na lumalamig ang aircon. (mine sprung a leak after 70K>)
these aircon guys are experts, having been in the business for years. if they say, hatak da dashboard,then hatak it is.. who would want to work harder than that required of the job?Last edited by dr. d; September 2nd, 2014 at 08:39 PM.
While ford does not specify time-based intervals for The AT ZF specifies a 8 year interval for the...
Ford Everest 2015
