View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 8,841 to 8,850 of 11542
- Jan 2014
- 158
May 14th, 2014 08:53 PM #8841Guys ano kaya magiging problem pag minsan napapatay mo ang engine tapos naka "D" kapa or "N" gear? Lately kasi may na eexp ako sa tsikot ko minsan hindi nag sstart yung engine mga 3 times ko ng na eexp last month yung first sa twice hindi nag crank so inalis ko yung susi den wait for 1 min then binalik ko tapos pedal sa break then yun nag start . Yung 2nd and 3rd incident naman once lang hindi nag crank pero nung inalis ko yung key tapos wait for 1 min then balik key try to start with pedal on the break nag start na . Im a bit concerned kasi baka matuluyang hindi na mag start. Pina check ko naman sa customers cradle hindi nag occur yung issue halos 5 to 7 times niya pinatay at on ng engine ni hindi nag crank lahat nag start sa 1st try niya so this is so intermittent .any suggestion guys?
Posted via Tsikot Mobile App
May 14th, 2014 10:25 PM #8842
^^ pagnapatay mo D or N or any other gears no problem.
di lang mag start yan kung wala sa N or P.
baka naman battery na ang problem mo or baka may maluwag na terminal. minsan pag AT symptom na yan ng bad battery eh.
- Oct 2008
- 525
May 15th, 2014 05:27 AM #8843Alam ko safety feature yan na hindi mag start pag wala sa "P" yung gear. What you can do pag naiwan mo sa D or N yung gear then off mo engine is to press the brakes, shift to P then start the car.
Nangyari yan sakin nung bago pa lang ako mag drive. Nagpa gas ako then sabi nung gasoline boy off ko daw engine. Then nakalimutan ko naka D sya pag off ko. Then nag offer sya na check under the hood so I said yes. Then nung napuno na gas ko nag try ako mag start then ayaw. Sabi ko ano ginawa mo bakit ayaw na umandar? Sabi nya "wala sir sinilip ko lang coolant nyo". Then that's the time na-realize ko naka D yung gear kaya ayaw mag start.
Now thankfully hindi nag start yung auto kasi if ever, I would have run over the gasoline boy since nasa harapan sya ng auto. Katahangan ko those days hehe.
- Jan 2014
- 158
May 15th, 2014 01:41 PM #8844I see pero pag iniistart ko siya asa "P" naman . Kakapalit lang ng battery nito last january pero i'll have it check regarding sa battery thanks guys!.
May 15th, 2014 06:36 PM #8845
Magstary ang at pag nasa P at N, but it will never, never start in any other gear like in D, R, 3, 2, 1 or L.
May 15th, 2014 07:13 PM #8846
Meron na ba sa inyo nakapagtry magclaim ng warranty sa gulong nyo? 18K Km, premature wear ng thread. Based sa investigation ng Casa, hindi sya cause ng low/very high tire pressure dahil uniform ang bakbak ng thread ng gulong.
- 52,859
May 16th, 2014 01:00 AM #8847
May 16th, 2014 06:18 PM #8848
The cracks are on the left and right side (inner and outer side) of the tire threads. Usually, cause daw ay alignment or low pressure. Pero sa case ko, both front tires suffer the same issue, with maintained 34-33 psi pressure. Yokohama Decibel series which is the stock tires ng Vios.
Under investigation pa dahil yung sira ng tires ay cracks, at hindi basta pantay na upod.Last edited by uno0308; May 16th, 2014 at 06:21 PM. Reason: added inner/outer side ***
May 16th, 2014 06:21 PM #8849
Di naman caused by the road surface? Tread ko parang pinatripan ng cutter. Puro uka at sugat. Steel parking kasi at matalas ang edges ng surface. Mas malala sa front dahil mas pwersado habang nagmamaniobra.
May 16th, 2014 06:28 PM #8850
EDSA,NLEX and Malolos Bulacan ang usual route ko, and normal na dadaan tayo sa pangit na surface. Same problem with you, cracks and small chunks na naalis sa thread ang problema. Di naman safety issue since thread lang ang may tama kaya pwede pang gamitin habang inaantay feedback ng supplier. The casa service advisor took photos of all tires and asked me to wait for a week para sa sagot. Sana, pumasok sa warranty. iba kasi ung nauupod sa nababakbak. Yun din ang sabi nila sa casa.
a car that i had sold more than ten years ago, to a bayan seller, is still apparently under my...
LTO car registration and late registration fees
