View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 567 of 580 FirstFirst ... 467517557563564565566567568569570571577 ... LastLast
Results 11,321 to 11,340 of 11582
    Quote Originally Posted by wenz_vios 1.3 x View Post
    i have another topic to discuss and ask you guys. regarding sa air intake. yung car is 1.3 uear old. so under warranty pa kasi 3 urs ata. but plan to change the air intake. ma coid ba ang warranty if ever mag change nang air intake manifold.
    mahina kasi hatak kaya paln to change air intake manifold or change the filter to aftermarket K&N.
    pls guys. waiting your advised.
    thanks
    wait wait... pag magpapalit ka lang ng air filter bakit kailangan palitan ang intake manifold?
    ung filter lang papalitan kung drop in air filter
    kung cone air filter, aalisin mo lang ung buong stock air box
    at most papalitan mo ung air tube
    hindi gagalawin ang intake manifold hindi gagalawin ang throttle body
    matrabaho mag modify from turbo charger to stock bro
    yun k&n filter naman, snake oil daw
    Sent from my RMX2020 using Tapatalk
    from stock naturally aspirated (NA) itu-turbo mo andami gagawin di lang mag kabit lang ng turbo tapos pag ibabalik mo sa stock andami gagawin din
    #11323
    sabi kasi dr.d balik stock daw pg mag casa [emoji28]
    hirap niyan
    si wenz_vios 1.3 x
    gusto niya mag aftermarket air filter like K&N
    ok lang yun madali ibalik sa stock
    #11325
    there are many other, easily-reversible, non-stock modifications one can make.
    let's not limit the discussion to turbo-ing.
    i have always wondered,
    if the aftermarket filter is really better than stock,
    why do not the car manufacturers install them as OEM in the first place?
    aftermarket (performance) air filters allow more air to pass thru
    sacrifice ng konting filtration
    #11327
    so, the definition of "better" varies with what one wishes to achieve.
    yes if you're goal is to make it easier for the engine to breathe then remove the air filter hehe
    that's crazy of course so the next best thing is to put an air filter that lets more air thru than OEM
    yun nga lang mas nakakalusot ang dumi
    #11329
    A K&N filter will cost 5x more than the usual air filter but with little to no gains in performance. If you want a small car with a small NA engine to perform better, fit it with grippier tires and find ways to lower its weight.
    Aug 2019
    #11330
    may mga nabasa kasi ako maganda daw ang aftermarket air filer like k&n. meron din nag offer simota ata brand. just asking lang ano po ang better choice
    Aug 2019
    #11331
    nag change kasi ako nang wider tire from 175 to 195. din sabi ni misis medyo na iba daw ang takbo sa uphill parang hirap si vios. din somebody says change air filter to have a better hatak daw.
    konting difference lang palit air filter
    if that's your only mod
    palitan mo na din ng exhaust
    Aug 2019
    #11333
    yung lang ang binago yung gulong. tapos nag lagay din nang spring cushion pala sa apat na spring front and back.
    yung exhaust di pa pinalitan nilagyan lang nang muffler sa nag kabit nang gulong saka spring cushion kasi umangat nang kunti si vios. kita yung stock exhaust kaya yun nilagyan nang muffler tip.
    Sir,
    since ang goal mo palakasin ng konte ang makina
    maliit lang ang gain pag magpalit ka lang ng air filter
    halos di mo maramdaman
    palitan mo na din ng exhaust para mas noticeable ang gain
    #11335
    lakasan nyo na lang ang tapaQ sa silinyador.
    Jul 2019
    #11336
    This comment will age well hehehe
    #11337
    I meant a grippier tire, not just a wider tire. You can look at Bridgestone Potenza or Michelin Pilot 4S but these are a bit expensive than the usual tires. Maybe the GT SX2 will be a more affordable option.
    Pero as what Doc stated, just press the accelerator pedal harder and rev the engine higher. I used to remember driving our old 2009 Jazz 1.3L AT. It was just a slow car and I have to get the revs high, above 4K rpm, to keep it cruising at 120kmh.
    haha
    oo nga naman
    bago mag isip ng ibang solusyon
    Aug 2019
    #11339
    haha
    oo nga naman
    suma sagad na nga daw ang apak. pero parang humina si vios. mula nung nag palit nag gulong saka nag lagay nang spring cushion.
    uphill lang naman pero di naman nasyadong slop kunti lang parang fly ocer lang na medyu mahaba ang slop.
    si misis kasi ang gumagamit. ala kasi ako ngayun sa Pinas.
    #11340
    Kung talagang nahihinaan na kayo sa Vios, benta nyo na lang. Di talaga oobra sa hatakan yung Vios 1.3L. Madali ibenta yan Vios.
    Kung gusto mo ng malakas ang hatak, bili ka ng kotse na may turbo gas engine. Brand new or used, marami pagpipilian. Mayrun sedan (Civic RS, Forte GT, WRX, Mazda6) or hatchback (Focus Ecoboost) or CUV (Forester XT, Escape Ecoboost, Coolray) or wagon (Levorg GTS).
Toyota Vios Owners & Discussions Thread
