View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 476 of 580 FirstFirst ... 376426466472473474475476477478479480486526576 ... LastLast
Results 9,501 to 9,520 of 11582
    Jun 2005
    #9501
    before replacing the O2 sensor, have your car scanned first. ang defective o2 sensor gives out an error code and check engine light. unless nag check engine, i doubt sira na yan.
    malaking gastos din yan at kung hindi sira, sayang pera. no refunds.
    personally, nung nag ganyan ang gen 1 at gen 2 ko, bumili lang ako ng throttle body cleaner pati contact cleaner.
    spray at linis ng throttle body using tb cleaner. spray din ng contact cleaner sa MAF sensor. tanggal battery din para reset ECU.
    total cost, 500 pesos. result, di na mababa idling ko.
    Sep 2013
    #9502
    ^^ sa mga di familiar sa terminology engine scanned, ang ibig pong sabihin nito ay icheck yung entire condition ng makina using a computer hooked up sa computer box or other input terminals in the engine itself. Baka my pilosopo dito na iscan ang engine sa xerox machine eh
    Jun 2014
    #9503
    Quote Originally Posted by RomeoAlpha View Post
    ^^^kun walang ac at bumaba siya 500rpm, mujhang palit air filter at pwedeng cleaning ng throttle body - air filter muna mas mura 350 petot.
    Ngayon kung hindi nasolve ng cleaning ng throttle body, i am definitely sure, O2 sensor na iyan.
    Malapit narin palitan air filter ko. oem air filter is changed every 20k. Last changed ko air filter mileage ko 20k. Now at 35k. Mura ng air filter ah 350. Sa toyorama ba yan? Last time bili ko 400 kay kingspeed. Any suggestion san ok magpalinis ng throttle body?
    Jun 2014
    #9504
    Quote Originally Posted by sirkosero View Post
    I don't plan to change o2 sensor w/o diagnosing the problem from casa or non casa. So far no check engine light. Ndi ako marunong mag DIY ng linis ng maf sensor at tb. Need pa pala tanggalin battery pag nilinis un? Any idea san pwede palinis throttle body at maf sensor?
    Jun 2014
    #9505
    Quote Originally Posted by kimbon View Post
    Grabe naman kung may nag isip ng ganun. Hahaha
    #9506
    Quote Originally Posted by _incubus19 View Post
    ano kaya ang finding ni xerox machine?
    .."check paper..." ?
    #9507
    Guys ask ko lng po may tumutulo kc sa ilalim ng dashboard ko tpos umaabot ung basa hanggang sa floor area ng driver and passenger seat.. Ng umpisa po nong huling ngpa washing ako.. Paano po kaya alisin water na naipon sa dashboard? Tks po sa sasagot..
    Jun 2005
    #9508
    tinatanggal lang battery to reset ecu and relearn yung mga bagong settings.
    yung cleaning, sa talyer or gas station na may service pwede naman. just bring your own spray.
    make sure you use throttle body cleaner and not carb cleaner. using carb cleaner will destroy you catalytic converter and o2 sensors. i got throttle body cleaner sa roadstar for 180 pesos.
    Jun 2014
    #9509
    Ah para sa relearn lang pala ng settings. May nagsabi na need baklasin un tb at maf sensor para mas ok daw kesa spray spray lang. Baka magka carb build up ata. Un tb cleaner pang tb at maf sensor na un? And what brand to buy for tb cleaner? Thanks
    #9510
    why baklas..? if a can of this stuff can do the job...
    Sep 2013
    #9511
    if you can shell out 1k to 1.3k it's better to send to casa or suking mekaniko. baka lang madamage ang maf sensor & others parts lalo na novice tayo sa paglinis. tutal bibili ka rin ng TB cleaner & etc..so konti na lang ang idadag mo. just think about it. goodluck
    Jun 2005
    #9512
    yung TB cleaner pang TB lang.
    yung pang Maf sensor, bili ka lang ng electronic contact cleaner na quick dry
    Jun 2014
    #9513
    From welcome rotonda up to ust, dahil traffic na monitor ko kung bumababa rpm kahit naka on a/c. Yes bumaba sya up to 500rpm. Sometimes 2 secs sometimes up to 4 secs. I'll change my air filter, spark plugs at oil muna. Then monitor ko ulit tapos saka ko nalang palinis un tb at maf sensor. Siguru sa casa nalang kc wala naman ako suking talyer. Sa mga nag advise at nag bigay ng tips maraming salamat sa inyu. Update ako kung may nagbago. Thanks ulit.
    #9514
    look for loose electrical connection in your engine bay and engine..
    Jun 2014
    #9515
    Noted. Thanks
    Nov 2012
    #9516
    Sir incubus ganito din problem ko e. Hindi ko pa napalinis yung tb at maf ko. Akala ko clutch kaya pinapalitan ko clutch assembly. Paki update kami sir ano ending ng problem mo.
    Jun 2014
    #9517
    Quote Originally Posted by gadtechs View Post
    Sige sir. Ndi ka nag padiagnose sa casa kung anu problem? Palit muna ako air filter spark plugs at oil. Tapos pag ganun parin try ko cleaning tb at maf sensor.
    Nov 2012
    #9518
    Hindi pa sir kasi parang nasanay na ako sa timplang ganun e. Hinahabol ko na lang pag nanginginig na.
    Oct 2014
    #9519
    Mga boss, san marecommend nyo na nagiinstall ng sideskirts?
    Dalawa na kasi tama ko magkabila. And instead of paying P3,700 for each accident (participation fee), I am contemplating of having it installed with sideskirts. P7,000 to P9,000 budget.
    Mar 2015
    #9520
    3,700 participation fee? Sino insurance provider mo sir?
Toyota Vios Owners & Discussions Thread
