View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 380 of 580 FirstFirst ... 280330370376377378379380381382383384390430480 ... LastLast
Results 7,581 to 7,600 of 11582
    Aug 2004
    #7581
    150kg is like two big people. Lagyan mo na rin siguro ng plywood ang trunk para mas ma spread out ang weight.
    Aug 2008
    #7582
    Thanks bro sa suggestion with regards to plywood. actually 5 pax plus the lanzones. sa daan pa lang natatakot na ako kasi for sure katakot takot na sayad ang aabutin ko, rocky road kasi.
    Aug 2013
    #7583
    share ko lang sir, yung tok tok tok sound (lumalagutok) sa steering wheel na solved na. culprit ay ang shock mounting. ang ginawa lang ng shop na pinuntahan ko they sprayed wd 40 and nawala na ang tunog.
    nagpalagay ako ng power cushion ganda ng effect hindi matagtag ang takbo, hindi na gano ramdam ang maliliit na butas sa daan, kahit sa cement road na puro bato nalang ang nasa surface hindi gano matagtag unlike before. psi front 32 back 30
    Sep 2013
    #7584
    Hi po, I'm just new here. I'm planning to buy Vios 1.3J. Meron po bang nakaka alam sa inyo kung how much yung DP and monthly?
    #7585
    Quote Originally Posted by bryan1207 View Post
    Iba iba po computation niyan. Much better tanong kayo sa dealership then tanong din kayo sa bank. Usually mas mababa rate ng bank.
    Sent from my Nexus 7 using Tapatalk 2
    Oct 2011
    #7586
    meron yard sale sa toyota pasig. low DP nasa 69K ang Vios M/T. monthly will depend on how long you will gonna pay for it.
    Sep 2013
    #7587
    Thank you both of you.
    Just sample computation lang po. Halimbawa 60 months po yung term. How much po ang monthly nun?
    Oct 2009
    #7588
    yung yard sale is gen 2.5 na vios?
    Sep 2013
    #7589
    Hello mga bossing. Nung thursday ko lang nakuha bago vios ko na 1.3e at. Parang medyo malakas gas consumption nya. Ganun po ba talaga or magiging matipid din sya later on? Thanks
    #7590
    i did read in an auto mag review, that their unit tested about 6 kn/li. they added that they expect the fuel efficiency to improve as the engine settles in.
    Aug 2004
    #7591
    Same experience. Been asking around, and a common complaint is that the economy is not what's expected in traffic.
    BUT:
    1. Traffic now is bad. Very bad. So it's hard to compare to the previous car fairly.
    2. These cars DO need to be broken-in before we see what they're capable of.
    3. The economy on the highway is actually great.
    So it's a wait and see for me.
    #7592
    BUT:
    so, for stop-and-go traffic, which would be more fuel-efficient: the 1.3 AT or the 1.5 AT ?
    Aug 2010
    #7593
    Always the one with the lower displacement. All because engine displacement is useless while idle.
    #7594
    ^Also consider that the engine isn't "laggy" off the line when you test drive. If a car isn't too responsive from standstill, the tendency of the driver is to mash the pedal more when the car is in neck-to-neck traffic.
    Jun 2005
    #7595
    Quote Originally Posted by vios1.3eat_user View Post
    First time I measured it (full tank at auto stop, same dealer, Petron XCS), got ~9.1, then 10.2 and now I'm getting ~12.7 km/Li on my 1.3E A/T (route sta.rosa ~ las pinas) and My odo is reading ~3200 km. Cruising speed at 80~90 kph on SLEX (Niky, thanks for the tip) although minsan di ko namamalayan nasa 110~120 na ako :D
    So FC seems to be getting better as the Vios gets "broken-in".
    #7596
    Quote Originally Posted by aDD_L View Post
    may factor din siguro yung nakikilala mo na yung car.
    Aug 2004
    #7597
    Quote Originally Posted by crave View Post
    Borderline na yan sir. Sakin 5 (big) pax + 2 kids + maleta kaya pa naman pero city roads lang. Ingat lang din sa preno dahil laki ng difference sa stopping power kung fully loaded.
    Aug 2004
    #7598
    Should be able to get about 20 km/l on the highway (even with the auto) when it's broken-in fully. The big problem with your route is the hills (between San Pedro and Alabang). The trick is simply to try to carry momentum up without pressing down harder on the gas, then let yourself speed up a bit on the downhill side (again, without pressing harder on the gas).
    The real problem is traffic... but if you can avoid gridlock, I think 14-15 km/l mixed is not an unrealistic goal.
    #7599
    ito yung pinaka mababang vios na nakita ko. halos pasok na sa wheel well yung hubcaps hehe
    Sep 2013
    #7600
    Thanks add_L. Siguro nga magiging matipid pag na break-in na ng husto.
Toyota Vios Owners & Discussions Thread
