1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
wait wait... pag magpapalit ka lang ng air filter bakit kailangan palitan ang intake manifold?
ung filter lang papalitan kung drop in air filter
kung cone air filter, aalisin mo lang ung buong stock air box
at most papalitan mo ung air tube
hindi gagalawin ang intake manifold hindi gagalawin ang throttle body
A K&N filter will cost 5x more than the usual air filter but with little to no gains in performance. If you want a small car with a small NA engine to perform better, fit it with grippier tires and find ways to lower its weight.
konting difference lang palit air filter
if that's your only mod
palitan mo na din ng exhaust
yung lang ang binago yung gulong. tapos nag lagay din nang spring cushion pala sa apat na spring front and back.
yung exhaust di pa pinalitan nilagyan lang nang muffler sa nag kabit nang gulong saka spring cushion kasi umangat nang kunti si vios. kita yung stock exhaust kaya yun nilagyan nang muffler tip.
Sir,
since ang goal mo palakasin ng konte ang makina
maliit lang ang gain pag magpalit ka lang ng air filter
halos di mo maramdaman
palitan mo na din ng exhaust para mas noticeable ang gain
I meant a grippier tire, not just a wider tire. You can look at Bridgestone Potenza or Michelin Pilot 4S but these are a bit expensive than the usual tires. Maybe the GT SX2 will be a more affordable option.
Pero as what Doc stated, just press the accelerator pedal harder and rev the engine higher. I used to remember driving our old 2009 Jazz 1.3L AT. It was just a slow car and I have to get the revs high, above 4K rpm, to keep it cruising at 120kmh.
sabi niya nanggaling siya sa 175 nag palit to 195
kulang kulang kasi detalye
di niya sinabi 195/xxRxx
so i assume original tire size 175/65R14
i assume went to 195/55R15
nagpalit din ng rim
so not only is the tire wider, the diameter is bigger
or 195/70R14 di nagpalit ng rim
but still a bigger heavier tire
pero ano itsura ng gulong?
wider tire nilagay sa stock rim ng vios na pang narrow tire
bulging sides
may mga nabasa kasi ako maganda daw ang aftermarket air filer like k&n. meron din nag offer simota ata brand. just asking lang ano po ang better choice
Sir, naglagay ba kayo ng aftermarket exhaust? Baka naman dahil sa mas maingay na yung exhaust nyo kaya nasasabi ni misis na hirap ang makina?
mag post nalang kasi ng photo ng kotse
baka sa itsura palang makikita natin bakit hirap ang makina
baka dahil sa pag porma ng sasakyan naka apekto sa performance
May Vios TRD dito sa subdivision namin, saksakan ng yabang with his todo body kits. Ang ingay pa ng exhaust nya tapos bilis pa magmaneho sa kalye. Kapag nasuwertihan nya ako, paparahin ko at test ko kayabangan nya sa stock rides namin. Hehehe
katawa feel na feel nila ung "race" car nila na puro superficial mods
i guess it's a phase a lot of guys go thru
sana huwag sila maka-injure o makapatay sa racecar-driving fantasy nila
so tama ako nagpalit din ng rim
from stock 175/65R14
TO 195/60R15
that doesn't look 55, lalo hindi 50
and as i pictured in my head ang tangkad ng kotse
look at the fender gap
big tires + fender gap
