View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 11,511 to 11,520 of 11542
February 14th, 2022 10:32 AM #11511
- 52,731
February 23rd, 2022 10:34 AM #11513
- 52,731
February 23rd, 2022 11:52 AM #11514errr,
is this normal for the car?
during the days of the old electromechanical engines, i.e., 1970s and older,
by the time for the 5000 km oil change, it was 'acceptable' for the sump oil level to have dropped about between the hi and low dipstick marks, sometimes more. that's about half a liter's worth of oil.
February 23rd, 2022 02:58 PM #11515
I don't think it's normal either. However, since I do the oil change myself, I found out that the volume between Hi and Low markers on the dipstick actually accounts for 1.5li of oil.
So between oil changes, even if I don't top off, I still don't go below the Min mark until the next change. I'm thinking this may have something to do with the piston rings already given the car's odo. No white/black smokes form the pipe though and engine still performs what I ask of it.
February 23rd, 2022 05:18 PM #11516
- Jan 2008
- 4,726
February 23rd, 2022 11:05 PM #11517its normal na may bawas talaga yan oil.. mas worried pa ako kung tumaas yung level kasi possible may fuel dilution yung oil.. mababawasan yan since yung oil masusunog yan.. pwede din yung talsik (mist) naka halo sa blowby gas na mapupunta naman sa intake
pero given that mileage malamang matigas na yung piston rings nyan.. same dun sa 3ZZ engine ng altis.. ganyan din nauubos, around 1 liter kasi matigas na pala yung piston rings.. no usok or hirap humatak symptoms..
- 52,731
February 24th, 2022 09:35 AM #11518
February 24th, 2022 11:05 AM #11519
Unfortunately for us here in Cebu, there's no road where I can run on a long and sustained high rpm. Although, every time I get the chance to drive the Vios, I usually redline it once or twice in the middle of the trip. Of course when engine is within normal op temp already.
June 24th, 2022 08:08 PM #11520
Toyota Vios Batman
DIY Tail Light Replacement:
1) Remove the four plastic clips with a flat screw driver
2) Disconnect the replay using the flat screw driver
3) Loosen/remove the two nuts of the two bolts
4) Pull out the tail light
5) Twist the three light bulbs counter-clockwise to loosen
6) Transfer the light bulbs to the new tail light
7) Install the new tail light.. reverse lang ng procedures.
Sent from my CPH1911 using Tsikot Forums mobile app
Xiaomi E-Car
