Results 51 to 60 of 192
- Jan 2003
- 73
September 25th, 2007 08:26 PM #51TVSS ? The value of this system will only be tested once your car been opened. They toyota has not lived up to my expectation with all others victimized without even a deterrent of a simple alarm.
Code alarm CA 310 has been installed in my Hilux a while ago still using the stock remote key. The good thing is you can adjust the sensitivity of the sensor to your liking. It works with the stock system.
I don't mind voiding the warranty of TVSS. Better to act now than be sorry later. If I have known TVSS it in the first Place was just a key less entry I did have upgraded immediately.
The TVSS is under question because the Car started even with the spare key (metal) with the TVSS activated ??????? and this is a big question mark !!!!!
Maybe they will tell that the metal key has IC in it?? No RF system will work if covered by metal like a KEY.
- Jan 2003
- 73
September 29th, 2007 04:20 PM #52In my case it's not working. I locked / armed myself inside the Hilux. then I start it with the spare key without remote. The car start, therefore immobolizer in my car not working. Check with your Innova. If many of us has the same experience then toyota has not met their commitment.
September 29th, 2007 06:06 PM #53
Check with your manual, the transponder key of cars with immobilizer is different from what you are holding right now.
September 29th, 2007 11:09 PM #54
- Jan 2003
- 73
September 30th, 2007 05:46 PM #55Not Winterpine.
Kid Audio of Binan Laguna. I lived in the south.
Winterpine is the sub contractor of toyota bicutan, the price there is 2X !
- Jan 2003
- 73
September 30th, 2007 05:50 PM #56The Manager of Service Advisor of Toyota Bicutan went to my office to show me the Car Key with immobilizer, the one with integrated remote and key. Well if he is wrong then we have a bigger problem. At that time i have not brought my spare key so no way to test what he is claiming.
I just tested the key without remote when I went home and the car start after I armed it went the other key.
September 30th, 2007 07:02 PM #57
Nakakatuwa tong thread na to'... Puro hihihi... :hihihi:
iam3739.com
- Jan 2003
- 73
October 7th, 2007 10:23 AM #58That represent a customer having problem with the car he bought
In my case, my Hilux . . . . at toyota bicutan
October 7th, 2007 11:41 AM #59
bakit yung corolla ko, kapag kalampag yung body... alarm
kapag inangat yung handle... alarm
pero sira yung remote, kaya manual lock na lang alang alarm ehhehe
- Jan 2003
- 73
October 12th, 2007 06:22 PM #60I suggest to include in the sticky thread those topics that concerns consumers woes and problems like toyota d4d, tvss and other manufacturers. in this way visitors and members will be informed.
Just imagine these problems are being "dedma" as if it is normal !
Kung puede lang naman . . . .
high idle RPM at engine start
