Results 731 to 740 of 1441
January 9th, 2015 02:01 PM #731
malakas ba talaga sa gas iyong vx 200 a/t na gas? parati kasi complain kaibigan ko eh
ito iyong totl nuong generation iya di ba?
- 52,731
January 9th, 2015 02:58 PM #732
- Aug 2012
- 2,767
January 9th, 2015 03:10 PM #733Yes, VX200 is the TOTL ng Revo.
It depends sa route mo and traffic conditions. Pati na rin sa maintanance ng sasakyan.
Twice kami lumuwas from Bataan to Makati and back last December. Acceptable naman para sa amin ang FC nya. This is for VX200 Gas A/T.
Route: Bataan National Road> Pampanga National Road > NLEX > EDSA > Makati
Trip 1
Distance = 251.63 km, Bataan-Makati-Bataan
Gas = 26.77 L (Full Tank method), Petron XCS
FC = 9.39 km/L
Trip 2
Distance = 285.29 km, Bataan-Makati-Bataan
Gas = 33.86 L (Full Tank method), Petron XCS
FC = 8.43 km/L
Pero kung gagamitin mo siya for daily driving sa city, tapos 1-2 passengers lang (including the driver) eh you better get a compact car na lang. Or switch to M/T or Diesel variant. But of course may Pros and Cons rin ang mga yan.Last edited by red_one; January 9th, 2015 at 03:30 PM.
- Apr 2012
- 3,469
January 9th, 2015 03:15 PM #734Deym I miss our GLX gas revo. Learned driving there.
Kahit na mas matulin at mas modern Grand Starex namin na mmiss ko yung Revo namin. Iba pa rin ang first love
- Feb 2009
- 22
January 14th, 2015 12:47 AM #735Hi guys,
Has anybody used Bardahl Maxtran 5000 80W-90 (API GL-5) on their transmission and differentials?
Went to a car shop and that's what they are using for other mpvs (advie, crosswind, etc).
Is this oil ok? Or anybody can recommend one?
Btw, my revo is the diesel 2L.
Thanks!
- Aug 2012
- 2,767
January 14th, 2015 11:49 PM #736^Based on Revo owner's manual..
M/T Gear Oil: SAE 75W-90, API GL-4 or GL-5
Differential Gear Oil: SAE 90, API GL-5
Pwede kang bumili sa casa. Toyota Differential Gear Oil is P285 per 1L bottle.
I don't know the price for M/T Gear Oil dahil A/T yung VX200 so ATF ang gamit ko.
- Jan 2015
- 2
January 17th, 2015 03:14 PM #737mga sir, balak ko bumili ng vx200 na matic..tanung ko lang kung may obd ba ito for diagnosis kase nakita ko parang andaming sensors eh.panu nyo mo malalaman kung anung sensor ang papalitan? TIA
- Aug 2012
- 2,767
January 17th, 2015 07:30 PM #738Yup, basta may ECU ang sasakyan eh meron diagnostic port yan. OBD II protocol ang gamit ng Revo. OBD II protocol is for 1996 and newer cars. OBD I protocol is for 1995 and older cars.
Defective sensors will usually trigger the Check Engine Light but not all the time. If you suspect that a sensor is malfunctioning, pwede mo pa-scan ang ECU. Based on trouble codes, malalaman kung anong sensor ang defective.
- Jan 2015
- 2
January 21st, 2015 03:43 PM #739for info lang po mga sir
owner of VX 200 2004 model
7K-E engine
gear km/h (mph)
1 34 21
2 58 36
3 93 58
4 133 83
1RZ-E engine
1 35 22
2 65 40
3 99 61
4 139 86
2L engine
1 34 21
2 57 36
3 92 57
4 124 77
- Jan 2015
- 2
January 21st, 2015 03:56 PM #740for info lang po ulit
Fuel
Selecting the proper fuel is essential for satisfactory engine performance.
Engine damage caused by use of improper fuels is not covered under Toyota's new vehicle waranty.
Fuel Type
Gasoline Engine
You may use either of leaded or un leadead gasoline
Diesel Engine
Use only diesel fuel.
Octane/ Cetane Number
7K-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 95 or higher.
1RZ-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 90 or higher
Diesel Engine: Select cetane number 50 (cetane index 45) or higher
Use of fuel with an octane or cetane number lower than stated will cause persistent heavy knocking. if severe, this will lead to engine damage.
if your engine knocks...
If you detect heacy knocking even when using the recommended fuel, or if you hear steady knocking while holding steady speed on level roads, consult your toyota dealer or mechanic.
However, now and then, you may notice light knocking for a short time whle accelerating or driving up hills. This is no need of concern.
Fuel Tank Capacity
55 L (14.5 gal, 12.1 Imp. gal)
