Results 761 to 770 of 1414
March 2nd, 2005 03:47 AM #761
yan ba ung parang pumipitik pitik na sound? parang ticking na back and forth?
meron din ako nyan. dati naman wala... pero ngayon, parang lumalakas e.
nasa 12k palang ako.
- Feb 2005
- 17
March 2nd, 2005 08:40 AM #762Originally Posted by pepengtom
March 2nd, 2005 09:42 AM #763
Originally Posted by solidaudio
blueish smoke? hmmm...
March 2nd, 2005 10:30 AM #764
me too! may white smoke at startup but its not eveident. I figure its just moisture since may water droplets sa exhaust.
initially problem ko lang yun squeaking sound sa loob, pero naremedy naman ng foam
- Feb 2005
- 17
March 2nd, 2005 11:05 AM #765Originally Posted by mazdamazda
March 2nd, 2005 01:55 PM #766
ung white smoke, natural lang yata talaga un pag cold start.
*solidaudio,
hindi e, parang hind dun galing..
bakit pala naglalaway ung tambutso ko? may tubig na lumalabas?
March 2nd, 2005 02:04 PM #767
lagi kasing exercised yung rav4 ko... hehehe... full range ng rpm nagagamit and madalas-dalas na ngayon ang high speed runs (140kph is already normal to me) dahil sa new NLEX...
suggest ko peeps mag fully synthetic na kayo... IMO, baka pag maling viscosity ang nagamit sa rav4 dun nagsisimula ang oil sludge
right now... may isa pa akong naalalang problem... nung after kong nabaha... kapag partially depressed lang ang clutch may faint noise... audible lang nga siya mula sa loob ng cabin... pero kapag fully depressed naman ang clutch nawawala... hindi kaya bearing lang ito or something?
after ko rin nabaha... parang mas maingay ang takbo ng alternator...
March 2nd, 2005 06:21 PM #768
on the matter of viscosity/consistency of oil, this morning i noticed that the oil has some black suspended particles. Ano kaya yon? Sludge? Katakot naman.
On sept 14 2004 at 12,000km nagchange oil ngTGFS (SL 5W-40), then in 16,000 km, dinagdagan ng elixir syn. oil. Now its 19,000 km.
Sludge na kaya?Last edited by -emil-; March 2nd, 2005 at 07:47 PM.
- Feb 2005
- 17
March 3rd, 2005 12:20 AM #769Originally Posted by -emil-
black suspended particles? is it relatively big the size of particles? better check it up sa mechanic mo or sa casa. pa open mo yung oil pan kung may matitigas na substances(sediments) na dumikit sa loob. tanong mo lang kung sino gumagawa ng elixir syn. oil, Tanong mo din sa TMP Customer service mismo kung specified ba nila ang oil na gamitin. If your under warranty pa, you would be better off kung gamit mong oil is specified ng TMP. pero pa verify mo lang yang sediments na yan.
usually ang sludge mudish color, chocolate milk shake. after a while titigas na yan. yung sa amin is tumigas na talaga like varnish, tapos ang naka clog sa oil pump namin is yung scale like sediments na blackish brown.
with regards sa RAV4 namin, we found out na if you total yung mga extended change oils namin sa casa would total to 7 missed change oils. we change oil naman regularly sa casa pero hindi TMO ang gamit nila and hindi talaga exactly every 5000kms. the biggest that we had was 14,000kms., What was very questionable about sa problem ng RAV4 namin was that, 15 days after the change oil at 100,962kms. nangyari ang sludging sa RAV4 namin. ayun nga dala agad namin sa casa and the next thing we knew sira na ang engine.
we are still in the process of negotiation regarding what will be done with regards our issue.
Good thing TMP has already offered to get into the issue na. Were happy with that na.
pero before nun, with the maximum pa nga of 14,000kms na hindi na pa change oil, hindi naman nagloko ang sasakyan. dun na xa 15 days after napachange oil na namin.
- Feb 2005
- 17
March 3rd, 2005 02:16 PM #770tsikot pips,
Thank goodness!
Our dealer and Toyota Motor Philippines has already took care of our RAV4's problematic engine. We are already in the negotiation table. Hope it all goes well!
Please learn from our experience. Always, ask Toyota for the specified engine oil and Proper engine maintenance.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
