^The dude's right. It's probably tire balancing. Ours used to vibrate at 100km/h. After balancing, there was no more vibration up to about 170km/h.
Hey guys, I've found out that the speed rating of the Yokohama Aspec A300 (Innova OEM) is 180km/h (S-rated). The documentation contains Australian standards, so it may be different from the standards here.
http://www.carbonblack.com.au/car-ty...formation.aspx
http://www.carbonblack.com.au/81/tyr...ed-rating.aspx
140 innova g 05 nightmist
55k++ odo hehe tanda na
last monday lang po right after pagnstall ng 17's pauwe nlex
i just tried it to test the handling and if the wheels are well balanced the car still can push pero di ko na kaya..
gas po pla. hehe
ot po:
ung avanza po kaya hanggang anu ang speed nya? parang nkakatakot po xa ihataw kc parang pagnadaanan xa ng mga barumbadong bus sa nlex parang lilipad xa. just curious...
^Hindi naman siguro, nakasakay ako sa kolorum na Avanza dati, mukang stable naman sa 120km/h+. Sabi nila nasa 150km/h+ ang top speed ng Avanza. Nice rims dude! Nga pala, baka nasa 150km/h na takbo mo nung 140km/h yung reading ng speedo. Big rims na kasi.
oks boss pero i still woudn't be confident with that kung sa nlex, city drive oks siguro kasi tipid.
thanks paps, ah ganon ba yun sir, akala ko ung takbo ko na 140 more or less 120 lang on actual speedcheck kasi mas malaki ung diameter nung alloy kesa sa goma un pala the otherway around,, pero mas mabagal po ata siya mag accelerate ngaun, though hindi nmn tlga ako madiin tumapak pero pakiramdam ko mas mahina siya ngaun.
>innova J diesel 150kph.... kaya yung hubcap ko na isa nawala na...'''![]()
>guys ask ko lang' yung GLX ba na strada 2.5 lang ba engine nun'??? may na-encounter kase ako ayaw magpa-overtake nakabuntot ako sa strada at 120kph na ang speed ko' kaya nung naka timing ako' ayun... iwan si mokong.....'''![]()
Hi Sir, if you are talking about the present Strada 2.5 GLX D-iD 4x2, then you are correct. Stradas of this Generation can harurot up to 180kph-190kph! Proven yan in a recent fun run.
...but it also depends on the diskarte of the Driver. Maybe si "mokong" wasn't in a rush...
Guys pwedeng sumali. 2.5 d4d din naman eh.
Yung Toyota Commuter D4D namin 2.5 same din ng Innova ang engine di ba? Naka 160kph ako sa SCTEX normal speed ko is 140kph then sumusundot ako ng 160kph. Yung driver naman namin naka 180kph. Believe it or not. Sayang walang tachometer kaya di ko alam kung redline na.![]()
180Kph on our toyota innova VVti.. Nakakagulat.. and still very stable... all my passenger where as sleep...
last tuesday 1am at NLEX, I did 170kph *5k+rpm, 2 pax
Innova G VVTi A/T,stock tires, 2300 ODO, 2 month old
medyo parang hirap pa yung makina dahil bago pa siguro..pero very stable siya..
No sweat reaching 180Kph on my Innova VVti with 6 passengers. Tried it several times * SCTEX.
