Results 441 to 450 of 525
January 17th, 2018 06:04 PM #441
- Apr 2010
- 201
- Jan 2018
- 1
January 22nd, 2018 02:57 PM #443mga sir good afternoon po.. manghihingi lng po sana ako ng advise, ano pa po dapat ipagawa maliban sa change oil (toyota innov E A/T 2016 model) ODO 27,000. Thanks po ng marami. bago lng din po kasi nag 1 year baka mahal na po mga charges.
- 52,731
January 22nd, 2018 10:28 PM #444the pms schedule is in the owner's manual, sir.
casas usually try to sell you more items than what is necessary.
"if it is not in the manual, it's probably an optional, and will probably inflate your bill if you allow them".
typical examples of optional: engine treatment, radiator or engine flush, de-carbonizing treatment, brake cleaner (controversial), oil and fuel additives...
i always say, "next time na lang. wala sa budget, e".
- Nov 2015
- 31
June 27th, 2018 04:46 PM #445Guys for the 40K PMS, maliban sa usual oil at oil filter, ang nakita ko sa manual ay yung Differential Oil plus yung Brake fluid ang kailangan palitan, tama po ba may nakikita kasi akong all fluids daw dapat palitan for 40K PMS, ano po ba talaga ang tama? 2015 2.5 MT
- Jun 2018
- 27
October 9th, 2018 02:53 PM #447Hello mga boss, san po reliable 40K PMS besides casa? Naisip ko po kasi marami na pong papalitan so okay pa rin po ba sa labas or balik casa na po dapat? Thank you.
- Nov 2018
- 1
- Nov 2018
- 7
December 3rd, 2018 01:23 AM #450Hi this is my 40k PMS Innova G 2015 MT
- change oil (DIY)
- change oil filter (DIY)
- change fuel/element filter (DIY)
- change cabin filter
- change air filter
- change differential fluid (service center (e.g servitek or any big service center) mahirap i pump ung oil papunta sa differential)
- change transmission fluid (same sa differential mahirap ilagay sa transmission)
- change coolant (DIY)
- change brake fluid (DIY)
- change power steer fluid (DIY)
- check brakes pads and shoe (if manipis replace if hindi pa next PMS will do) (DIY)
Oil - shell Rimula R4x 6.5L
Filter - Vic C-111
Fuel Filter - Vic F-193
Cabin and air filter - Generic
Differential/Transmission/Coolant - Toyota
Brake Fluid - Prestone
Power Steer - STP power steering fluid
Brakes - Hi Q Brakes
FYI every 40k is major PMS for our beloved car.
After niyan every 10k change oil and check brakes.
Then 60k change oil check brakes replace fuel filter
70k change oil check brakes
80k repeat above and include replacement of timing belt.
Ung about gulong nasa sa inyo yan check lagi kain ng gulong if hindi pantay then do camber and alignment if nag wiggle do balancing. If pudpod talaga replace na.
Its only for me. Never ako nagpacasa except 1k maintenance. 100k plus na odo ko d pa naman sumasabog ung unit ko hahaha.
Happy PMS everyone.
Xiaomi E-Car
