Page 45 of 53 FirstFirst ... 35414243444546474849 ... LastLast
Results 441 to 450 of 525
    Aug 2009
    #441
    Quote Originally Posted by tribal View Post
    noob question lang po.
    ilan po engine oil capacity ng innova 2010 diesel?
    wala po ako manual and iba iba kasi nababasa ko sa google mahirap na magkamali.
    6.9 nasa manual kapag palit filter pero 6.5 lang nagagamit ko sa actual.
    Apr 2010
    #442
    Quote Originally Posted by Sleepcare View Post
    Thank you po
    Jan 2018
    #443
    mga sir good afternoon po.. manghihingi lng po sana ako ng advise, ano pa po dapat ipagawa maliban sa change oil (toyota innov E A/T 2016 model) ODO 27,000. Thanks po ng marami. bago lng din po kasi nag 1 year baka mahal na po mga charges.
    #444
    Quote Originally Posted by gdlopez View Post
    the pms schedule is in the owner's manual, sir.
    casas usually try to sell you more items than what is necessary.
    "if it is not in the manual, it's probably an optional, and will probably inflate your bill if you allow them".
    typical examples of optional: engine treatment, radiator or engine flush, de-carbonizing treatment, brake cleaner (controversial), oil and fuel additives...
    i always say, "next time na lang. wala sa budget, e".
    Nov 2015
    #445
    Guys for the 40K PMS, maliban sa usual oil at oil filter, ang nakita ko sa manual ay yung Differential Oil plus yung Brake fluid ang kailangan palitan, tama po ba may nakikita kasi akong all fluids daw dapat palitan for 40K PMS, ano po ba talaga ang tama? 2015 2.5 MT
    Mar 2018
    #446
    True.
    Palabok na lang halos mga yan.
    Jun 2018
    #447
    Hello mga boss, san po reliable 40K PMS besides casa? Naisip ko po kasi marami na pong papalitan so okay pa rin po ba sa labas or balik casa na po dapat? Thank you.
    Mar 2004
    #448
    Try Speedy Fix ... or Zix ...
    Nov 2018
    #449
    do they allow to bring your preferred oil?
    Nov 2018
    #450
    Quote Originally Posted by nscostales39 View Post
    Hi this is my 40k PMS Innova G 2015 MT
    - change oil (DIY)
    - change oil filter (DIY)
    - change fuel/element filter (DIY)
    - change cabin filter
    - change air filter
    - change differential fluid (service center (e.g servitek or any big service center) mahirap i pump ung oil papunta sa differential)
    - change transmission fluid (same sa differential mahirap ilagay sa transmission)
    - change coolant (DIY)
    - change brake fluid (DIY)
    - change power steer fluid (DIY)
    - check brakes pads and shoe (if manipis replace if hindi pa next PMS will do) (DIY)
    Oil - shell Rimula R4x 6.5L
    Filter - Vic C-111
    Fuel Filter - Vic F-193
    Cabin and air filter - Generic
    Differential/Transmission/Coolant - Toyota
    Brake Fluid - Prestone
    Power Steer - STP power steering fluid
    Brakes - Hi Q Brakes
    FYI every 40k is major PMS for our beloved car.
    After niyan every 10k change oil and check brakes.
    Then 60k change oil check brakes replace fuel filter
    70k change oil check brakes
    80k repeat above and include replacement of timing belt.
    Ung about gulong nasa sa inyo yan check lagi kain ng gulong if hindi pantay then do camber and alignment if nag wiggle do balancing. If pudpod talaga replace na.
    Its only for me. Never ako nagpacasa except 1k maintenance. 100k plus na odo ko d pa naman sumasabog ung unit ko hahaha.
    Happy PMS everyone.
Toyota Innova PMS (Periodic Maintenance Service) Thread
