Page 70 of 775 FirstFirst ... 206066676869707172737480120170 ... LastLast
Results 1,381 to 1,400 of 15487
    Oct 2011
    #1381
    Sir you should never shift from P or N to any drive (1, 2, D, R, etc) gear without fully pressing the brake pedal. Baka po masira A/T nyo. It should be in the vehicle manual.
    ah okay, sabi ko nga ba.
    May 2005
    #1382
    Quote Originally Posted by Chito View Post
    Planning to buy an Innova G this December, price quote from Toyota Makati are as follows:
    1. SRP less 45,000 cash discount
    2. Free LTO registration (3 years)
    3. Tint
    4. Carpet Matting
    5. Seatcover
    6. Rustproofing
    7. Complete Set of Tools
    Ano pa ba pwedeng madagdag sa freebies. Thanks.
    If Toyota will not extend their promo, then better book your order by Nov 29 to avail of 60K discount and a chance to join the raffle.
    #3 - What brand is their free? Request for a full front tint for the windshield.
    Apr 2005
    #1383
    Regarding AT. It is common practice to full press brake before changing to 'drive' position. But at times when im in full stop, i occassionally change gear from 'neutral' to 'drive' position without pressing the brake and i felt a little jerking when i change to drive position. normal lang ba ito? pwede ba i-adjust para mawala ung jerking?
    I've beeen driving AT's for 10 yrs and it's a must that you press on the brakes when shifting from N to D or from N to R to P so that your car won't suddenly move forward or bacakward and your foot is not stepping on the accelerator pedal The jerking motion is normal as the gears are engaging. Just read your manual as it's explained there.
    Apr 2005
    #1384
    Just want to ask about the automatic climate control. Talaga ba ang maximum setting ng temperature is 28 degrees?
    Nov 2011
    #1385
    3. Tint
    4. Carpet Matting
    5. Seatcover
    6. Rustproofing
    Sir, I got a Microtex cleaning kit as an added freebie..
    Nov 2011
    #1386
    Quote Originally Posted by amir1223 View Post
    alam ko jan kahit sa casa ka magpakabit,same procedure din ang gagawin compared if sa labas ka magpakabit...price outside is of course cheaper by 50-70% than casa...u can try cobra,autopage,viper, etc alarms outside...kung sa casa gagawin yan,mag-cut din nman ng wires yan,kasi kung may adaptor or plug-in lang,e di sa outside market meron na rin nun...
    still it is on your own disposition if you'll risk to void the electrical warranty by going to outside autoshop and save a lot of money or sa casa ka pakabt but for sure,t will cost you a lot...ako after 2 months na makuha ko unit ko,sa labas na ko nagpakabit ng alarm & sensors....hope to c the new ones her sa next EB..good day..
    Thanks, bro.. Might as well go for the non-casa installation then--for very practical reasons..
    Oct 2011
    #1387
    I envy those newer models with automatic climate control. ung sa akin analog dial control lang. pwede bang i-upgrade un?
    Oct 2011
    #1388
    Quote Originally Posted by SEALANDER View Post
    yes, thanks bro. good thing i posted in here. bago pa masira ang AT ko.
    Jul 2011
    #1389
    18 C yata max at min ay 28 C ng auto A/C
    Apr 2005
    #1390
    Quote Originally Posted by MrQ5 View Post
    Siguro nga 28 lang ang maximum. Sobra lamig na kasi tinaasan ko temperature hanggang 28 lang. Pero napansin ko lang kanina naka auto mode ang aircon nung binuksan ko blower sa likod parang hindi lumalamig. Pero nung manual mode na lumamig naman. Normal ba yun?
    Apr 2005
    #1391
    One more thing when naka stop ka sa traffic always shift to Neutral or N. Never make it a habit na naka Drive tapos naka preno. Malakas makasira ng tranny yan.
    Oct 2011
    #1392
    yes, naging habit ko na un. i used to drive a manual vehicle before kaya nakasanayan ko na ilagay parati sa neutral. maka save din daw sa FC.
    Feb 2011
    #1393
    Paano kapag naka full stop ka di ba nakaapply handbrake, tas shift from N to D then remove hand brake. Or need pa rin na dumaan sa foot brake? Alam ko lang kasi basta dapat pag maglilipat ng gear ay dapat nakastop specifically from N - D vice versa and pati yung sa R -D v.v. or R - N v.v. Sensya na newbie kasi with an Innova E A/T. Thanks.
    Oct 2011
    #1394
    Quote Originally Posted by ACidGaMbiT View Post
    walang footbrake ang innova. basta palagi full press ang brake pedal when changing gears kahit na full stop pa ang auto mo nakakasira daw ito sa AT. HTH.
    Apr 2005
    #1395
    Medyo nalito ako dito. Do you mean that when you shift from N to D while preasing he brake pedal nakakasira ito ng transmission? And magkaiba ba ang foot brake sa brake pedal?
    Apr 2005
    #1396
    Pag naka handbrake ka step on the brake pedal first then shift to D then release the handbrake then the brake pedal. The reason why you should press the brake pedal before shifting to D is to prevent you from accidentaly stepping on the accelerator pedal while shifting gears to avoid rearending the vehicle in front of you. As you can see may jerking motion yan when you shift from N to D.
    Oct 2011
    #1397
    yes, magkaiba ang footbrake sa brake pedal. ang ibang kotse tulad ng Camry meron doon footbrake pero walang handbreak.
    Full press muna ang brake pedal then shift from 'N' to 'D' position then release ung brake pedal. Ang nakakasira ay ang hindi pag press ng brake pedal ung transfer na agad from 'N' to 'D'.
    Apr 2005
    #1398
    Okay i get what you mean. Yung footbrake ay parang handbrake lang yan kaya lang it is applied with the foot.
    Oct 2011
    #1399
    Congrats on your new ride bro! did you get the V variant?
    Maybe talagang dapat press muna ung brake before changing to drive position. Kailangan full press din ang brake kung light press lang, may jerking pa rin.
    G Variant sir. congrats also. Buti AT din kinuha nyo. Saka lang ako Nag N pag complete stop then I always press the brake pero ramdam pa rin yung jerking na parang tinapik ka sa balikat . I think its normal kasi gagalaw na kagad yung gulong once na dumaan sa R at D yung gear selector...
    Oct 2011
    #1400
    Quote Originally Posted by 1845ers View Post
    Hi Guys,
    Re-post ko lang ulit...thanks
    Ask ko lang kung ok lang na mag shift ng oil from fully synthetic to mineral oil for D4D engine? If ok, need ko pa ba ng flush b4 mag change oil.?
    Thanks!
    Di ako expert pero kung ako lang no need to flush lalo na kung wala naman foreign substance na nakapasok sa engine mo like sabon. Also depende din sa current condition ng engine mo. kung wala naman problem better not to do it. better ask a mechanic.
Toyota Innova Owners & Discussions [continued 3]
