Page 50 of 775 FirstFirst ... 4046474849505152535460100150 ... LastLast
Results 981 to 1,000 of 15487
    Jan 2011
    #981
    Quote Originally Posted by Mile2 View Post
    LPG SGI kit has its own ECU, piggy backed on OEM Toyota Innova ECU hence no tuning required after the initial LPG ECU tuning from the dealer. LPG ECU mimics the OEM ECU, so it runs like gasoline.
    Our VVTI Engine does not need tuning or adjustment as stated on the aluminum plate in the engine bay.
    Saan, Magkano and kelan po kayo nagpakabi ng LPG? Thinking of getting one. Someone from manilaautogas valle verde pasig quoted me for P55K to 65K depende sa tanke.
    May 2007
    #982
    Quote Originally Posted by marz View Post
    Wow Mam pasalubong ha,, sa EB ko na lang kunin. hehe
    TIA Mam.
    hahaha... sige, uwian kita ng tsinita.
    Feb 2011
    #983
    Quote Originally Posted by liv View Post
    mam ako din isang tsinita ha! yung ***y po hahah. chaka po size 7 ako, pasalubong po! hahaha.
    Feb 2011
    #984
    Quote Originally Posted by 1845ers View Post
    thanks sir...
    saang dealer ka sir? sabi kc sa akin ng SA ko sa Toyota North Edsa di daw cover ng warranty yung undercoat ko kasi kasama daw siya sa freebies...nakakainis nga e, bakit ganun pag free walang warranty?
    sakin din naman freebies sir eh. may warranty dapat yan sir. demand for it. magkanu sasakyan tapos yung undercoat na freebies walang warranty. di ata tama yun. BTW, toyota cubao dealer ko sir.
    #985
    as far as fuel consumption, my innova j, d4d can give 11+ km/l city driving, about 14 to 15 km/l hi-way
    #986
    Share a li'l bit of experienced. Kahapon nagpunta kami Naga city. from Quezon prov. it took about 598km from my odo. 7 passenger+1kid and a lot of baggage. pauwi puno pa ng pinya roofrack.Going there sa Bitukang manok kami dumaan. Ganda at sobrang steep pala nya and pabalik sa baba na kami dumaan(baka mahulog mga pinya).may mga part na talagang pangit yung daan. hindi pantay pantay yung asphalt. FC ko from my calculation 12.56km/l D4d manual gamit ko. 2000petot na diesel.42.80 petron regular diesel nga po pala. siguro may sobra pa mga2-3 Li. yung excess.
    Aug 2006
    #987
    Quote Originally Posted by vic2rem View Post
    It was P40K (2008) for SGI kit with Toroidal tank fitted underneath replacing the spare tire. Had DIY my spare tire to be fitted at the back of the 3rd row seat with special pedestal and tire cover. I was able to recover the cost after 10 months of use (savings on fuel cost). Having a toroidal tank (Donut Tank) is the best option since your tank is placed outside the car at least for Innova, Fortuner and the likes.
    You can call GreeFuel, please check this thread for contact numbers.
    http://tsikot.com/forums/car-economy...tations-50159/
    You can also do some readings on this thread for LPG users feedback.
    http://tsikot.com/forums/car-economy...nued%5D-72927/
    http://www.greenfuel.com.ph
    Jun 2009
    #988
    my right rear tire was ran flat for quite a distance. san ba mura bumili ng goma? stock rim pa rin gamit ko. nagtanong kasi ako ng Yokohma ASPEC 3,950 ang quote sa akin. naghihinayang ako. kasi gagawin ko lang syang spare.
    any ideas?
    Dec 2009
    #989
    Sir Mile pa help naman baka pwede pa post naman ulit pic kung pano tanggalin yung cabin filter ng innova, d ko na kasi ma-access
    yung mga pic sa previous page. TIA
    Oct 2008
    #990
    Quote Originally Posted by desertfox615 View Post
    any ideas?
    I think there are Tire Shops na nagbebenta ng mga slightly used tires at mas mura. But as for me, I rather buy a brand new one para sure yung quality. Mahirap na, baka ma-run flat uli kasi slightly used na siya.
    Aug 2006
    #991
    any ideas?
    Sa Evangelista P1,200 kuha ko last 2 months ago. Pili ka na lang ng malalaking tire shop doon and then ask for those trade-in tires. Yung nakuha ko halos bago pa dahil may balbas pa yung thread and the production date is last quarter 2010. Isang set yun nakita ko with steel rims pero napilit ko na tire lang ang kailangan ko. I had to buy one that time since na-gutter ko yung front tire ko at nabutas sa gilid.
    Aug 2006
    #992
    Sensiya na marz mahirap ng mag-upload ng pictures ngayon dito sa tsikot. if I remember right there's a sticker procedure on the side of the globe compartment. Open the globe compartment and you'll see the sticker on the side.
    Dec 2009
    #993
    No problem Sir Mile, tignan ko na lang sa globe compartment. Thanks for the info.
    Jun 2009
    #994
    guys, thanks for the feedback. just settled with brand new ASPEC tires. cost me 3900.
    Oct 2008
    #995
    Wala ba sa Manual yung procedure?
    Buksan mo muna maigi yung glove box cover. Sungkitin mo yung left side pa-kanan then yung right side pa-kaliwa sabay hila pababa yung cover hanggang nakalaylay na siya.
    Makikita mo na yung filter then pwede mo nang hugutin palaba matapos mong ma-release yung lock.
    Washable yung filter ng water spray gun. Sun dry or blow dry then ok na.
    #996
    Open and empty out the glove compartment.
    You will find that the glove compartment has a protusion on each side to keep it from falling out when open.
    Push the side of the glove compartment to one side so the protusion is able to pop out.
    Repeat for the other side.
    The entire glove compartment will come off.
    You will be able to see the ac filter on the lower right side of the cavity.
    Its fitted in like a table drawer and you can simply pull it out to clean.
    just did it and clean the same with a dish washing soap.
    Dec 2009
    #997
    Ok na nalinis ko na rin cabin filter kahapon.
    1st light, Ryan thank you for sharing the procedure.
    Mar 2011
    #998
    how often ba bos usually ang cleaning ng cabin filter?ako kasi di ko pa nalilinis yung sa kin since nakuha ko unit ko this april..thanks!!
    #999
    medyo madumi na yung cabin filter after 5 months. ako I wash the filter at least every 2 months.
    May 2005
    #1000
    Just bought an Innova E 2011YM last June. It did not come with the usual bottle of touch up paint. Should I ask for one?
Toyota Innova Owners & Discussions [continued 3]
