yan nga sana i-comment ko joey kay inoj kya lang baka ma offend eh, sana po sir inoj di kayo clutch driver...baka po yun paa sa clutch pedal lagi po nkatapak ng konti, im just guessing sir.hehehe hope youd ont get offended.
kaya ayoko makipaglibing gamit manual sakit sa paa kakarealease sa clutch para ma neutral agad.
That is already a good deal for 9.5K. Kaso marami klase ng G5. meron may demon eye meron wala. may dual led na demon eye meron din single led. pero mas maganda kung meron talaga shroud para ma-fill yung headlight. masyado maliit yung built-in shroud ng G5. try mo sa sulit may seller yata ng shroud dun. around 2K / set.
OEM sealant is actually very good. may mga tricks din para ma-reseal din ng maayos ang headlight . although you have sealed the headlight properly may tendency pa rin na mag-moist ang headlight due to trapped moisture. kailangan pasingawin ang moisture sa loob before you close the rubber seal.
hu hu hu hu hu... nasabitan ako ng motor kanina on my way to school ng anak ko. wwwaaaaahhhh!!!!
para sa rider ang haba ng guhit na ginawa mo dalawang panel ng pinto sa passenger side ang pinsala. sa kabila nito, hangad ko pa rin ang iyong kaligtasan. hari naway wala ka ng maperwisyong iba.
Drive Safely to all, good am & God bless!!!
Good morning peeps! My apology for this noob question... My innova is on a 23k odo reading already. A year and half old. Never had my tires rotate ever since. Even my reserve tire haven't been use also. My question is, will there be any problem if i do it now? Use the reserve tire and do the rotation? Thanks!
Should be no problem, spare tire shouldn't degrade much in 1.5 years so you can pair it up with a new tire. For me its better if the spare is included in rotation to prevent it from degrading.
*Mile2
That's very unusual, the fronts usually wear out much faster than the rears.
Yes I knew that, but mine really wears out evenly on four tires, so by that time I just bought 3 new tires and just use on old one for spare*Mile2
That's very unusual, the fronts usually wear out much faster than the rears.![]()
mga sir ask ko lang , how many facelift does innova have including ung 2012 model na?
good day..
just got my innova G dsl m/t last week. im new to diesel engines & may mga katanungan lang ako:
1. Saan gasoline station kayo nagpaparefill? Petron, Shell or Caltex?
2. Saan kayo nakakakuha ng mas magandang FC between the big 3?
3. Ano gamit niyo engine oil viscosity & grade? mineral, semi-synth or fully synth?
4. Ano bulb ng fogs? Will it void the warranty if i replace them with all weather or yellow bulbs?
Oh I see. Thanks sir!
Wolfmania, I'm not sure if they did. I think they don't. Kasi pag nagpapa-PMS ako, they never told me about tire rotation. Siguro nag-aantay lang sila sabihan din. Syempre, dagdag trabaho sa kanila. hehe. Lam mo naman yang mga yan, pag di mo sinabi, hindi gagawin unless may kikitain sila. On my next PMS, I'll will include it already on my request. Thanks sir!
Thanks din sir Wh1stl3r!
Now, how about if I did the tire rotation including the spare tire? As I see kasi, there's no big difference in terms of worn out among the other tires vs. the spare. Parang di pa naman gaano na-wornout yung iba. Or I just see it the wrong way? Thanks for your input guys!
mga bosing, makatanong lang...
san ba makakabili ng ganito aside sa casa?
