Page 1432 of 1533 FirstFirst ... 133213821422142814291430143114321433143414351436144214821532 ... LastLast
Results 14,311 to 14,320 of 15330
    #14311
    Quote Originally Posted by Amirqwe View Post
    Ito po yung 1000 kms PMS ko sa Toyota.
    1. Oil + Oil Filter + gasket = 2600 pesos
    2. Miscellaneous = 510 pesos
    Bawal ipatanggal. Ito raw kasi yung mga glove, pamunas. Basta yung mga ginamit daw ng mekaniko.
    Grabe rin pala sa Toyota. Unang singil sa akin ay 10,000 pesos dahil fully synthetic oil at kasama yung mga add-on nila tulad ng engine cleaner. Pinatanggal ko yung add-on tapos mga nasa 7k na. Pinagawa kong ordinary oil (mineral oil siguro) na lang.
    6 months interval lang kasi kapag fully synthetic tapos 3 months kapag ordinary oil.
    Regarding naman sa transmission ko, pinipilit ng mekaniko na hindi raw niya mareplicate pero nung pinoint out ko sa kanya yung tunog(kasi nagagawa naman niya), sinabi niya lang na normal lang daw yun. Pumunta siya roon sa isa pang Innova tapos nangyayari rin paminsan minsan yung hard shifting (+tunog). Normal lang kaya na paminsan minsan lang nangyayari sa akin yung hard shifting. Liable kaya sila kapag may mangyari sa transmission ng Innova namin?
    Hindi sila liable. Stop dreaming. If youre doing maintenance with them and if there should be any failure during the warranty period they will cover anything that failed. Clutch and brakes are consumables though.
    Jan 2009
    #14312
    I tried it bringing it before to the shop to have it scanned but at the time it doesn't light up so they cannot check it right? For a week probably it light up once or twice especially when it is long idle in stoplight.
    CEL or SRS?
    I thought you just said that you reset it whenever it lights up.... and there's a question of how you're doing this.
    Anyway, some DTCs are stored in memory and can be extracted during a scan.
    Feb 2019
    #14313
    CEL or SRS?
    Yes when it happens I reset it meaning I turn off the engine and then start the engine again. I will bring it to the shop for my next pms and let them see if it can be retrieved in the memory. Mine is CEL.
    Jan 2009
    #14314
    Yes. But, make them admit that you both heard something to which they couldn't (or wouldn't) identify the root cause. That's going to be on record and a receipt which you can cash-in on a rainy day. If they don't want to put it in writing, then compel them to look into it. Ganun lang yun. Wala silang pupuntahan.
    #14315
    For those who owns an innova what is your current odo reading? Mine is around 110K still running good just have the problem with check engine light which turns on occassionally especially when at full stop.
    2005 model.
    140K km.
    early on, the fuel water contamination light lit up.
    i did everything in the manual. no dice.
    in disgust, i replaced the entire fuel filter assembly. it was still cheap, back then.
    that solved the problem.
    Jun 2005
    #14316
    Matik ba yan? Pansin ko may gear hunting innova lalo sa eco mode. Not complaining. Normal naman yun
    Sent from my MI MAX 2 using Tapatalk
    #14317
    2005 model.
    140K km.
    Ours is 2008 model, gasoline AT... Approx 62kkm... Changed 4 tyres, front brake pads and 4 shocks....No issue so far...😎😍😉
    #14318
    Ours is 2008 model, gasoline AT... Approx 62kkm... Changed 4 tyres, front brake pads and 4 shocks....No issue so far...������
    innova is a well-built car.
    it is a shame that the new model is larger than the previous.
    medyo mahirap sakin, dahil makitid neighborhood namin...
    mas type ko tuloy na bumili ng slightly used, kaysa kumuha ng bago. sigurado pa sa EP.
    Jun 2005
    #14319
    Di naman ganun kalaki difference doc..
    Dec 2019
    #14320
    i've just remembered last year i drove a 2nd gen innova 2.8 and went to my aunt's house in bulacan. napakakitid din ng pathway papuntang garage nila and then nahirapan akong ipasok duon. they also had an innova g 2.5 d4d 1st gen kasya siya. kaya pinark ko na lang beside of their house instead.
    then narealized ko na puedeng magkasya ang 2nd gen innova dun because my uncle told me that he parked a hiace gl grandia (yung flat nose version) and it fits in the narrow pathway to the garage.
Toyota Innova Owners & Discussions [continued 3]
