From what I understand the owner bought/received his unit last Oct., 2011(?). The Certificate of Registration (CR) was dated Jan., 2012(?),- kaya he was claiming it was a 2012 model/unit.
However, the facelifted Innova 2012 is still coming out next month....
There lies the difference, bro.
14.7K:cow:
Thanks for the info sir, pero bakit daming ads sa sulit nakalagay 2012 innova pero pag tingin mo sa mga pics mukhang 2011 model naman, parang panloloko na to di ba para lang makabenta
http://www.**************/index.php/...&featureType=1
ahh simple lang yan sir. kasi halimbawa bibili ka ng innova this 2012, like ngayon na mismo, year 2012 ngayon, so 2012 talaga ang lalabas sa CR ng car.
yung mga 2011 nabili like mga na acquired yung unit ng mga sept-december, 2012 na din nakalagay dun.
lahat ng mga bagong innova ngayon sir 2012 pa din. yung lalabas na bago is a new facelift version lang na 2012 model din kasi this 2012 lalabas.![]()
HTH. :D
Bought my Innova G last November. So basically it's a 2011 model. Pero sa CR 2012 model nakalagay. I guess this is just for registration purposes. I received my license plates just last week. At yung sticker is for years 2012-2014. I paid in advance for 1 year so 2015 na ang next registration. Alangan naman 2011 ang model tapos ang sticker 2012-2014?
Hindi talaga dikit even original foglamps from Toyota. I had mine installed sa casa (original lamps and switch but without the original steering wheel lever switch - kasi Model E). The Innova's foglamp design is not similar to other vehicles (for example the vios, altis or camry) where the fit and finish is SPOT ON and with proper mouldings. Maybe the newest facelift will have that though.
Same here. Foglamp is used more than the headlights. It provides dimly lit areas with enough illumination without the need for turning the headlights on. I have the habit of turning on my lights when entering building parking areas or when it's cloudy or raining during the day. Learned this from a "driving guru."
mga sir, when we turn on the fog lights, hindi lang sya yung nagbubukas pati yung two(2) small lamps sa inner side ng front headlights.
meron bang way to keep that two small lamps to not turn on? plan ko kase palitan ng HID yung sa headlights ko and parking/fog lights ko, or meron din bang HID para dun sa two small lamps?
thanks in advance
the two small lights is the park light. you cannot replace them with hid. the best replacement you can put there is led if you want it to be white or any other color.
That's correct sir, fog lamp switch is in series with the park light switch. You can not activate the fog lamp without turning on the park light switch.
Your electrician can rewire it to be independent, downside is your electrical wiring will be tampered.
For the head light's dome park light, if you need white colored bulb. Just buy the white multi-LED bright bulb. I'm using the white 8-LED bulb for park light and it is comparable to stock park light bulb (only that it is white)![]()
yes sir park lights yun. magbubukas talaga yun kasi di bubukas ang fog lights pag di naka on park lights.
tama sila sir, LED is the best replacement for the park lights. pwede din replace mo ng bulb na lang din tapos amber ang color, ganda.
tanong lang mga sir RE parklights and foglights for the innova G/V variants.
ok lang ba na naka turn on yung swtich ng fog lights palage? yung pag ON mo ng parklights eh ON na din kagad ang fog lights and vice versa pag i turn OFF?
kasi my usual practice eh switch ON parklights chaka ko lang i switch ON ang fog lights then pag papatayin, turn OFF ko ang parklights chaka turn OFF ang fog lights. TIA. :D
Ericson, yung innova ko E variant lang pero I have the original Toyota foglamps with the Switch mounted on the leftside panel. I think this is near the side mirror switch if equipped (G and V). For me, I have this fog lamp switch always ON, di ko na sya pinapatay. So yung foglamps turns on/off whenever I switch the parklight on/off. I don't see any problem naman.
tol erick parehas tayo...ako pag-on ng park lights, bukas na din kaagad ang foglamps and its been like that since pinkabit ko yung foglamps last July...pag open ng park lights, bukas na agad pati fogs...same concern, mga bos, ano ba ang maipapayo nyo?thanks in advance..
Just curious, Does the G and V variant use Denso for the aircon?
I have 2011 E variant and I can confirm it uses aircon by Sanden
Okay lang na lagi naka ON ang switch ng fig lamps. Wala naman kuryente papasok pag naka OFF ang parklight switch.
