Results 14,251 to 14,260 of 15330
- Feb 2020
- 23
- Feb 2020
- 23
March 6th, 2020 12:41 PM #14252
- Feb 2020
- 23
March 9th, 2020 12:43 AM #14253gawa na po radiator ko and 2 hours ko syang test drive. mag tatanong ulit po ako kasi pure distilled water ang nakalagay ano nilalagay or akmang coolant para sa innova diesel 2005? paano po mixture. iba iba kasi nakikita ko at sinasabi ng iba kaya gusto ko po manggaling mismo sa mga owner ng innova. salamat po.
- 52,731
March 9th, 2020 12:45 AM #14254they're color-coded, po.
innova uses the pink coolant.
pre-mixed or concentrate.
if you want to be sure, buy from the casa.
it may be more expensive, but hey! how often do we have to replace our coolants...
in the olden days, distilled water was fine, because engine blocks then, were iron or steel.
today, most engine blocks are aluminum alloy. they may need the anti-oxidation properties of modern coolants.
- Feb 2020
- 23
March 9th, 2020 02:05 AM #14255
March 9th, 2020 09:56 AM #14256
Using just distilled water in your cooling system was never ok, iron block or otherwise. But water is water... you could put in brown water in a pinch and it will definitely work to cool the engine.
However, the lack of the necessary additives (or the presence of unnecessary chemicals and substances) will cause it to eat into vulnerable parts. What you'll end up having in your cooling system is an aquarium of electroplating materials.... or simply, corrosion. Ever seen the water pump impeller go 'bald'?
Coolant that is designed for your vehicle helps to inhibit those reactions from happening. And quite equally, using the wrong coolant may even be more harmful than good.
The coolant does three major things:
1. Cool the engine
2. Inhibit chemical reactions
3. Lubricate moving parts (ie. pump, thermostat, valves, etc.)
By using just distilled water, you've just effectively ignored #2 and #3.
March 9th, 2020 10:09 AM #14257
& raises the boiling point around the engine's operating temps.
Those of you who are planning to rebuild your engines(where you can drain em totally dry of old coolant or water) can go the ultimate option....Evans Waterless Lifetime Coolant.
Evans Waterless Coolant, Prevent Engine Overheating
Waterless Engine Coolant - Jay Leno's Garage - YouTube
Wheeler Dealers, Edd China Triumph TR6 Evans Waterless Engine Coolants Conversion - YouTube
https://www.topgear.com.ph/features/...a2600-20190225
Evans Waterless Coolants PH
- Feb 2020
- 23
March 9th, 2020 09:18 PM #14258oo nga po. anyway po kaya po distilled water lang muna ang nilagay ko kasi kakaconvert lang nung radiator ko kaya under observation sya that time sayang kasi kung my problem pa pala sa rad at ibaba ulit sayang yung coolant. bukas po makakapunta na ako sa toyota bili ng coolant. or need ko pa e flush si radiator? may pang flush ba ng radiator or diretso ko na si coolant? TIA
- Dec 2019
- 2,072
March 9th, 2020 10:26 PM #14259nung kinonvert yung radiator, nandiyan pa rin yung coolant reservoir mo?
“Normal” water, tap water typically has dissolved solids, minerals, which can concentrate or leave deposits…everywhere, and those deposits are next to impossible to remove.
Distilled water is the only water that should be added, and only if the engineers recommend it in the Owner's Manual. Distilled water can oxidize steel and cast iron, but does not contain the harmful minerals like tap water.
A 50/50 mix is a common recommendation that combines the heat transfer of water with the protections of coolant. Consult your Owner's Manual.
- Feb 2020
- 23
March 9th, 2020 10:54 PM #14260yes sir intact parin and working si reservoir. noong kinarga yung 6 liters na distilled water nagkulang sya ng siguro 1liter pa not sure, sir 3.5liter na coolant sir ang ilalagay ko? 50/50mix
edited: wala na po owners manual baka meron po kayong pdf or soft copy sir pa share. TIA
Xiaomi E-Car
