Page 1385 of 1549 FirstFirst ... 128513351375138113821383138413851386138713881389139514351485 ... LastLast
Results 13,841 to 13,850 of 15485
    Jan 2009
    #13841
    Mataas na ba yung handbrake? If so, baka kailangan din ng adjustment yung drum brakes.
    May 2019
    #13842
    Sir pinalitan ko dn po kc sabay n ung brake shoes. Try ko po i bleed di kc nbleed ung fluid.
    #13843
    Quote Originally Posted by archcos_5 View Post
    Hi Sirs,
    Ano po kaya ang cause kapag ang brake mo eh nag iba ng pakiramdam, nag palit po kc ako ng brake pads. Kc before, pag press ng brake pedals hndi sya nag ssink ng mejo malalim, may force na nalaban pag pnpress ang pedal dahil ata sa ABS system ito.
    Kaso after mag palit, feel ko may mali, although makapit nmn brakes pero prang may hinahanap pa ko like sa dati kong pag brake. Ano po ba ang solution dito? Thanks po mga sirs
    some brake pads, when new, need to sink in.
    bleeding the brake lines may also help, if this hasn't been done in a long time.
    the handbrake should hold well already, after only a few clicks, say, 2 or 3.
    adjust if needed.
    of course, there is always the "wrong installation" issue...
    May 2019
    #13844
    adjust if needed.
    Thanks po sa pag reply sir, ill I'll continue to fix observe if the problem will be resolved.
    Jun 2005
    #13845
    adjust if needed.
    Agree ok this. Bedding in would last a few kms. Para makuha ng pads yung contours ng rotors as well as remove then protective layer sa packaging. Some mechanics sand the new pads to help.
    Since bago pads, i hope nacheck na din yung rotors if they are still good.
    Sent from my MI MAX 2 using Tapatalk
    Jan 2009
    #13846
    Anybody with a 2.5D Innova that’s using the recommended xW30 oil, as opposed to the more popular xW40?
    How’s the engine characteristics in terms of power delivery, noise, fuel and/or oil consumption? I know it’s subjective so please try your best to be as objective as much as possible.
    May 2015
    #13847
    52k km fuel filter of our Innova 2015 as in madumi talaga [emoji23]
    Sent from my Redmi Note 5 using Tapatalk
    May 2019
    #13848
    Sir ilan ang suggested mileage bago palitan yan?
    May 2015
    #13849
    Puro inspect lang kasi nakalagay sa Manual eh. Amin kasi mag 5 years na sa october. So stop and go traffic at mejo mataas na rin accumulated mileage na.
    If i were you. Pwede mo siya inspect once a year be careful lang din sa gasket nya para di ma worn out kaka alis tanggal.
    May 2019
    #13850
    Ok sir, same pala tayo mag 5 years na sa October innova 2.5g white hehe. Thanks po and drive safe always [emoji4]
Toyota Innova Owners & Discussions [continued 3]
