Results 13,831 to 13,840 of 15485
- Feb 2008
- 903
- May 2015
- 146
May 27th, 2019 08:48 AM #13832Wala namang problem sa pag upgrade from Halogen to LED. Pero may bad experience ako noong ginawa ko yung upgrade na yun. Pili ka lang ng magandang LED at maganda reviews if you're planning to buy sa Sh***e or L****a
. I bought it from shop S. 4 months lang tinagal and my experience was static when using the FM Radio while driving at night at syempre naka-on yung Led headlights ko. I switched back to halogen and bought a Pegasus bulbs. Far far better than my stock bilux osrams and slight improvement from my previous LED bulb.
Regarding sa projector. I be bake pa ata yang headlamps mo? Para matanggal yung seal (based sa napanood ko sa youtube hehehe). Mejo matrabaho if DIY but if you have budget for a retrofit mas maganda
Sent from my Redmi Note 5 using Tapatalk
- 54,232
May 27th, 2019 08:53 AM #138331. stick to stock.
2. remove the front windshield tint (heh heh).
3. have the lights properly adjusted for throw. if lights are already clouded over, replace them.
4. have eyes checked.
5. get feet back on the ground. hey! we're not schumi speeding for his nth win...
keep in mind, that the maximum allowed speed limit is for ideal daytime driving conditions only.
at night, it is always prudent to drive more slowly.Last edited by dr. d; May 27th, 2019 at 08:56 AM.
May 27th, 2019 04:26 PM #13835
- May 2019
- 14
June 1st, 2019 11:19 PM #13836Hi Sirs,
Ano po kaya ang cause kapag ang brake mo eh nag iba ng pakiramdam, nag palit po kc ako ng brake pads. Kc before, pag press ng brake pedals hndi sya nag ssink ng mejo malalim, may force na nalaban pag pnpress ang pedal dahil ata sa ABS system ito.
Kaso after mag palit, feel ko may mali, although makapit nmn brakes pero prang may hinahanap pa ko like sa dati kong pag brake. Ano po ba ang solution dito? Thanks po mga sirs
June 1st, 2019 11:34 PM #13837
- May 2019
- 14
June 1st, 2019 11:40 PM #13838
June 1st, 2019 11:42 PM #13839
- May 2019
- 14
June 1st, 2019 11:50 PM #13840
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
