Results 13,801 to 13,810 of 15485
- Apr 2009
- 59
May 11th, 2019 10:03 AM #13801DR D & SLEEPCARE - I finally got the clip off. Here's my procedure, maybe it can help guide others.
1) I pushed in the seat foam in the area of the knob so I could see (barely) the clip with a flashlight. Inikot ko yung knob so I could study the shape of the clip & how it goes in the groove (may pics din naman sa Google image for the knob and clip). 2) I used one finger to try and remove it (space is too tight for 2 fingers). I used a quick & somewhat forcefull movement with my thumb along the diameter of the end of the knob (the end that is attached to the adjustment "rod"). Just be careful that the clip doesn't fly off ! I cupped my other hand around the area in case it wants to fly out of the car (sayang din kasi yung clip). 3) Ingat lang when pulling knob out so you dont strip the plastic splined threads of the knob. Thanks again to you both. Patrick
- 54,230
May 11th, 2019 10:08 AM #13802
May 14th, 2019 11:44 AM #13803
- May 2019
- 1
May 14th, 2019 03:38 PM #13804Mga sir, currently using Zic X7 10w-40 on Innova D4D 2015. Pansin ko lang na parang nagbabawas ang langis compared to Delo (not much pero a few mm from Full mark sa dipstick). Mileage is 53k kms, 3k into the new oil after oil change ng 50k
Read somewhere na this is “normal” for daily driven diesel car? Thoughts po
- 54,230
May 14th, 2019 11:49 PM #13805
May 15th, 2019 09:13 AM #13806
- May 2019
- 14
May 18th, 2019 12:51 PM #13807Hi sirs,
Ask ko lng po ano po kaya prob, bigla nlng po naka on lng ang left side rear brake lights ung umiilaw kapag nag brakes, qno po kaya ang problem kc once bnuksan ang kotse naka on na agad sya and nag rrelight kpag inapakan ang brakes. Help nmn po ng solution thanks. Bagong palit po sya mismo ng rear lights kc nabasag ung dati, whole assy po ng lights ang pnalit hndi lng bulb, kaya hndi po sa bulb ang prob. Pti pg replace nya genuine toyota po sya hndi nmn ganun, nka raan araw ko lng napansin.
Thanks po innova 2015 po G variant
- 54,230
May 18th, 2019 01:00 PM #13808kindly re-narrate. hindi ko ma-intindihan. include which side of the car is doing what, as well as the status of the ignition key.
however,
is it possible, you did not turn off the alarm?
in some model alarms kasi, if you open the door without first turning off the alarm, the lights will blink on and off for some time.
sino nag-replace ng light assembly? perhaps you should bring it back to them as "free back-job".
- May 2019
- 14
May 18th, 2019 03:20 PM #13809Hi sir please see link : INO.jpg - Google Drive
yan nka encircled is naka on lng ang lights nya, which is supposedly dapat kapag inapakan lng brakes dba tsaka iilaw yan? Ano po kaya prob jan, naka On lng sya bsta pag inopen mo ang ssakyan.
May 18th, 2019 04:17 PM #13810
lotus elise all the way! 2004 edition
Lotus returns...
