Page 1276 of 1549 FirstFirst ... 117612261266127212731274127512761277127812791280128613261376 ... LastLast
Results 12,751 to 12,760 of 15485
    Jan 2017
    #12751
    Gandang araw mga mam/sir.
    Naka 1k na po ung innova namin, ano ano bang dapat ipa-check up sa dealer? Sabi kasi sakin nung mga napag tanungan ko na, wag daw muna synthetic oil ang gamitin since bago pa lang. Double check ko din daw kung ano ung gagawin kasi baka mapagastos daw ako na di naman kaylangan.
    Eto ung mga nasabing ipacheck ko pag punta ko daw sa dealer
    change oil (wag synthetic, kaso di ko alam ano ung standard)
    change oil filter
    tires
    brakes
    Salamat po sa magbibigay ng inputs
    Jul 2016
    #12752
    Quote Originally Posted by kimcarl0s View Post
    change oil filter
    tires
    brakes
    Mineral oil pag ayaw mo synthetic mas mura. Pag wala naman problem sa tire and breaks mo wag mo muna pagalaw. 2 weeks ago nag pa 1k pms din ako change oil and filter lang. May separate thread yata sir para sa new innova dun ka na lang mag post next time. Thanks
    Sent from my SM-J500G using Tsikot Forums mobile app
    Feb 2006
    #12753
    ask ko lang po kung ano pwede ipalagay na gear oil at power steering fluid sa 2010 innova diesel po nasa 80,000km na rin po kasi yun sasakyan namin ano po okey na ilagay thanks in advance po
    Mar 2013
    #12754
    Quote Originally Posted by jovz View Post
    Para sa akin any branded gear oil (MT), atf (AT) and atf also for power steering will do. Pabaliktad mo lang ng 3 or 4x ung reservoir ng power steering (kung pwede)consumed ka malamang ng 2ltrs of atf.
    Feb 2006
    #12755
    Quote Originally Posted by joey36b View Post
    ah yun po kaya sa gear oil mga ilan liters po kaya MT nga po pala yun innova namin thanks sir
    Mar 2013
    #12756
    Google mo lang sir baka magkamali pa ako hehe
    Jan 2017
    #12757
    Thanks sir! Kita ko na ung 2016 innova thread
    taga bacoor din pala ako sir
    Apr 2017
    #12758
    it could be something as simple as "there's nothing wrong, sir. normal disk brake heat-up lang yan", to brake caliper repair, to ...sky's the limit.
    bearings... libo (x2?).
    caliper repair kit.. hundreds.
    breakdown on the road.. 5K towing alone. baka hindi puedeng hila, baka kailangan ng flatbed...
    replacement of other nadamay na piyeza.. ???
    aksidenteng naka-bangga...!!!
    peace of mind.. priceless! imagine driving the vehicle at night.. expecting something to happen at any moment...
    ...taga-makati lang pala kayo! there are evangelista and pasay rotonda. but beware of the usual vultures.
    Good day! now my front wheel is ok , so far di na sya ganun kainit. after ko makarating ng house inoff ko na ung engine close door pero ung susi nakapasok parin, panay alarm yung sa dashpanel ba yun dko lam bat nagkaganun tot tot tot tot na continue cxa.tas pag tinanggal ko na ung susi nawawala naman,1's na ipasok ko lang ung susi not turning on.panay alarm lang cxa.this is not a normal sa car ko 1st tym lng talaga anu kaya dahilan nun bat nagkaganun?
    #12759
    Quote Originally Posted by mr.pantherQ View Post
    maybe your alarm is needing replacement. or you have a grounded sensor somewhere.
    when you start the engine, the alarm naturally is turned off, and it does not bother you with its bells and sounds.
    pa-tingin nyo po, at baka ma-ubos ang baterya isang araw at hindi nyo na siya ma-start.
    Aug 2008
    #12760
    Ask ko lang po kayo guys, nagpalagay ako silicon sa fan blade ng innova ko kasi mahina na daw ang buga ng hangin, pero after malagyan ng silicon indeed lumakas ang buga ng hangin at idle. But na obserbahan ko kapag tumatakbo ng mabilis may malakas na humming sound coming from fan blade dati wala naman ako naririnig na ganun. May particular brand ba ng silicon na dapat for innova. Appreciate ur replies. Tnx
Toyota Innova Owners & Discussions [continued 3]
