Page 1275 of 1549 FirstFirst ... 117512251265127112721273127412751276127712781279128513251375 ... LastLast
Results 12,741 to 12,750 of 15485
    #12741
    The brakes on the Innova are small to begin with. And the oem Yokohamas being a hard compound makes the brakes work harder. Stickier tires will help. On long downhill stretches it pays to use engine braking to lessen stress on the brakes.
    I like the D3 of the Innova on the fast rolling hills of ternate. Suits my driving style...
    Apr 2017
    #12742
    Both front wheels?
    And I assume when you stated "sobrang init" you meant the rim/s is/are as hot as a clothes' iron....
    You need to have them checked. Good decision not to take it on a trip...
    I only check left front wheel that time and inobserbahan ko araw2 everytime ginagamit ko ung car and i notice na mainit talaga and sa rear wheel hindi naman ganun.nirun ko lang naman is 20-30km house office lang naman dito sa makati. ang sabi ata ng mekaniko ung bearing daw na malaki saka maliit and i have no idea rin pagdating sa parts na un,ayun dko pa pinagawa kasi under observation ko parin and hindi kami nakabiyahe ng province for safety reason na rin kasi mahirap.
    #12743
    Quote Originally Posted by mr.pantherQ View Post
    patingin nyo na po.
    your next warning might be total bearing breakdown, as in, tukod ang gulong.
    also, fixing it earlier might result in cheaper expense than fixing it later. habang wala pang nadamay na parte.
    Mar 2013
    #12744
    Maybe stock-up caliper hindi bumabalik ng todo ang piston kung walang noise if meron wheel bearing pero mapapansin na un sa ingay. O/H caliper need niyo sir, cheap lang repair kit.
    Apr 2017
    #12745
    patingin nyo na po.
    how much ung ganung parts? buti i decided na wag ibyahe ng provice kung ganun pala kalala ung mangyayari at gabi pa.
    2 days ko na d nagagamit ung car ko and ipapagawa ko na kesa sa kalye ako abutan ng sira. thanks sa advise
    #12746
    it could be something as simple as "there's nothing wrong, sir. normal disk brake heat-up lang yan", to brake caliper repair, to ...sky's the limit.
    bearings... libo (x2?).
    caliper repair kit.. hundreds.
    breakdown on the road.. 5K towing alone. baka hindi puedeng hila, baka kailangan ng flatbed...
    replacement of other nadamay na piyeza.. ???
    aksidenteng naka-bangga...!!!
    peace of mind.. priceless! imagine driving the vehicle at night.. expecting something to happen at any moment...
    ...taga-makati lang pala kayo! there are evangelista and pasay rotonda. but beware of the usual vultures.
    Nov 2014
    #12747
    Good day!
    Uwi kami ng Ilocos sa end of April, first long drive ko with the Innova 2015. Before that magpapalit ako ng gulong, due na rin kasi siya. My current wheels are the stock 205/65 r15. Nag-iisip ako mag change ng tire size: Here are my options:
    a) 205/65 r15 (stock size and mags)
    b) 215/65 r15 (using stock mags)
    c) 205/55 r16 (must change mags)
    I'm looking at the Delium brand of tires.
    My questions are:
    1) if I change tires, mag change din ba ang tire pressure na gagamitin ko?
    2) any review/comments on the Delium brand of tires?
    TIA
    Jul 2016
    #12748
    Kung mag papalit ka tire sir mag babago slightly speed reading mo. May mga nakikita ako 205/70r15 mas mataas sya sa stock tire. Same tire pressure din pag mag palit ka size. Ok naman yata yang delium madami ako nakikita gumagamit nyan. Para sakin mas maganda parin srock size madali hanapin size
    Sent from my SM-J500G using Tsikot Forums mobile app
    Mar 2013
    #12749
    Quote Originally Posted by Alex Tamayo View Post
    Good day!
    My questions are:
    TIA
    Kung magpalit ng mags masmaganda syempre may + factor sa auto. At the sametime masnagiimprove ang traction ng tires, ganda kapit sa kurbada at brakes. Pagmaybudget go! Hehe
    Jan 2011
    #12750
    Guys tama ba na pag G or V yung innova mo hindi mo kailangang baklasin yung dashboard para malinis yung AC? palit lang daw ng cabin filter dahil J and E na walang auto climate control walang cabin filter.
Toyota Innova Owners & Discussions [continued 3]
