Page 1271 of 1549 FirstFirst ... 117112211261126712681269127012711272127312741275128113211371 ... LastLast
Results 12,701 to 12,710 of 15485
    Jan 2009
    #12701
    Quote Originally Posted by archcos555 View Post
    Mga sir nakapag reface na ko ng rotor disc and palit brake pads nung Thursday. Ang mejo issue ko naman sa ngayona y parang ang lamya ng brakes or spongy pag pinangbbrake, ano po kaya cause neto. Pinableed nmn daw ng mechanic ung system. Anyone na may same experience dto? Thanks
    If everything was done right and there really is still enough rotor thickness, you just need to re-bed the brakes. Search the net for the procedure.
    May 2009
    #12702
    ganyan din yung kabayo ko nun. pinareface ko tapos palit bagong brake pads. mejo spongy kahit na fully bled na lahat ng brake lines.
    ginamit ko lang ng ginamit....tapos hard braking parati. ayun bumalik naman sa dating pakiramdam yung brake pedal.
    Sep 2014
    #12703
    Quote Originally Posted by miked View Post
    Ganun va sir akala ko kc may problema tlga. kc naninibago tlga ako dinala ko ult sa mekaniko ganun daw tlga un hayaan muna mag seat in ba yun, gamitin lng daw ng gamitin at babalik dn daw sa dati un. Ganun lng pla tlga pag bagong salpak. Nangingimay ako ang weird pag mag bbrake eh. By the way salamat sir sa input nio God bless[emoji4] [emoji4] [emoji4]
    Feb 2015
    #12704
    GOOD DAY... plano ko bumili sa online store na turbocharge kit... ilalagay ko sa innova gas at ko. ok lang kung gumastos ako malaki.. but the question is pede ba lagyan? kasi sa online kasi nakikita ko meron for gas engine.. saka ung obd tools ba yun na pde ireset ung odo bali naka apps sa android phone... either ipabili ko sa thailand ung ganung item sa brother ko na nasa thailand. kasi plan ko paastigin ung innova ko na model 2010, tas may nakita ko na foglamp napang 2010 na malapad na mayron na syang DRL.
    speedlab on fb. they're the only option imo.
    #12706
    Yes, at least, kung gumastos ka ng malaki, pag may problema, may tatakbuhan ka dito. Ü
    Speedlab ka na lang.
    Jun 2012
    #12707
    Quote Originally Posted by maze View Post
    Palit ka na lang ng kotse. Alphard v6. Yan astig.. innova kahit lagyan mo turbo, ganun pa rin yan. Di aastig yan
    Sent from my SM-A9000 using Tapatalk
    Sep 2004
    #12708
    Anyone here have problem with their odometer and speedometer readings? meaning not accurate? Is the speed sensor the solution to this? or is there other options.
    My problem is my Automatic Tranny, and the mechanic said need to fiz first the speedometer problem for the tranny problem to go away. Thanks.
    Feb 2015
    #12709
    Quote Originally Posted by dct View Post
    mahal ang alphard wew... i have another car yung montero newlook . . . experiment sa innova ko, lalo na yung engine na palagyan ng turbo... nway thanks sa advice . . saka ung odometer irereset ko sya gamit ung obd tools na ipapabili ko sa brother ko sa thailand.
    Apr 2010
    #12710
    ^ kung gagawa ka nang kalokohan, wag mo nang i-announce unless 999% sure ka na hindi mo ibebenta sa market yan
Toyota Innova Owners & Discussions [continued 3]
