Results 9,381 to 9,390 of 15485
- Oct 2013
- 1,181
October 9th, 2014 07:25 PM #9381Yup dependent yan paps sa floater, floater lang naman ang sensor ng sasakyan sa tangke.
- 54,247
October 9th, 2014 07:27 PM #9382that's why, if you may notice, some gas boys will slow down the fuel delivery as the fuel level gets "near the top". they are slowing down, so's the remaining air in the tank can have the chance to exit thru the filler neck. if the air is not able to go out because it is being blocked by the onrush of incoming fuel, the neck gets filled up, with a large air bubble still in the tank. when you start the engine, nakakalog ang tangke at filler neck, baba si fuel at alis si air. then all of a sudden, you have space for 5-10 liters more!
the longer the filler neck, the more prone this can happen.
our PUJ drivers are even more intense... they shake the jeep to and fro, to get rid of the flat air bubble against their flat-topped gas tank. pag garahe kasi, ang usapan ay dapat full-to-the-brim ang tangke para sa susunod na mamamasada..Last edited by dr. d; October 9th, 2014 at 07:30 PM.
October 9th, 2014 08:23 PM #9383
October 10th, 2014 11:10 AM #9384
Sino na po ang recently naka pag pa PMS for 40,000 kms? specifically for VVTi models. pede po makita yung job order? need ko lang po malaman ung mga kailangan palitan at yung qualtity ng mga fluids na i replace during PMS.
Maraming salamat po
- Aug 2008
- 164
October 10th, 2014 04:23 PM #9385
October 10th, 2014 09:10 PM #9386
Yung pinto na pinagawa ko off yung color compared sa rest ng paint. Sobrang dark. Yung sa bumper naman, diniretso lang nila pinturahan kumbaga hindi man lang ineffort na tanggalin kaya yung gaps sa fender tska bumper may paint. (Pero medyo pinagbigyan ko na din sila sa door since 7 years na din yung paint ko during that time kaya medyo understandable na din na faded na yung ibang part ng paint)
October 13th, 2014 07:05 PM #9387
Good day!
Tanong ko lang
have anyone experienced yung tumutunog paginopen and close yung
rear hatch
and how to remove the squeaking sound tapos ang bagal pa kumilos
- 54,247
October 13th, 2014 07:51 PM #9388you can try lubricating the pivot points at the roof.
but my suspicion is, it's your left and right springs.. and unfortunately, once they act up like what you are describing, there's no solution but to replace..
but hey! it's easy to replace, and they ain't expensive.
- Sep 2007
- 192
October 13th, 2014 08:43 PM #9389Mga sir, how's your rear wiper? Yung sa akin kasi may squeking sounds pa rin akala ko mawawala along the way but 2 years old na ganun pa rin. Meron bang remedy dito? Tnx.
October 13th, 2014 09:06 PM #9390
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
