Results 9,371 to 9,380 of 15485
- Oct 2014
- 6
October 5th, 2014 01:37 PM #9371May nabasa akong sa ibang forum na 215/55R17 ay nagfit sa kanyang innova (lapad ng rim ay 7"). I just wonder kung ang 215/60R17 ay kasya pa rin, lalo na sa front wheel.
October 7th, 2014 11:47 AM #9372
We also replaced the timing belt earlier than recommended. Cheap insurance relative to the cost of the engine. The belt itself is cheap, around 10K? The other things to be replaced (tensioners?) are a bit expensive.
*remrem
Best and simplest thing to do is find a dealer who will agree to test fit the new rim/tire combo on the front. Once on the ground check for rubbing by (gently!) maxxing out the steering left and right.
Can anyone recommend a reliable OEM Toyota parts dealer? Need a new water pump. Ours is shot at 130Tkms.
October 7th, 2014 04:06 PM #9374
Thanks!
Just wondering, who has the highest mileage on a D4d Toyota Innova here? Maybe you can share what major parts needed replacing and at what mileage.
- Jan 2012
- 82
October 8th, 2014 01:01 PM #9375Meron po ba dito nagpacalibrate ng fuel gauge for vvti engine type innovas?
tia
- Jan 2012
- 82
October 8th, 2014 03:17 PM #9377Hindi na po kasi tama yung reading sir, nasa full pa rin after a 200+km ride. baba lang cya sa half pag less 10 liters na.
Meron na po ba dito, who has the same experience as mine... turn engine off; gas up to the brim (hindi yung auto stop), then turn on the engine for a few seconds then pwede na ulit ifill up ng ilang liters pa(normally mga 5-10L).
thanks
- Aug 2008
- 164
October 8th, 2014 08:56 PM #9378Gud pm po, ask ko lang po if there's anyone of you guys who had your car repainted or retouch by CAR MAGIC ok po ba quality ng service nila they do home service daw and 1 day lang compared sa casa na 3 days. Magma scratch kasi innova ko
- Oct 2013
- 1,181
October 8th, 2014 10:48 PM #9379Baka may problema float mo. Yung filling to the rim mo na experience, baka yung hangin sa tank na nakulob ng mag fill ka, then ng magstart ka nakahinga yung hangin kaya you can add again. Kapag to the rim ang filling, try mo ishake yung sasakyan mo habang kinakargahan para lalabas hangin.
October 9th, 2014 07:02 PM #9380
The range info displayed in MID naka depende ba yun sa floater?
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
