Results 931 to 940 of 1815
February 23rd, 2011 05:30 PM #931
February 23rd, 2011 05:32 PM #932
February 23rd, 2011 07:39 PM #933
I'm curious about nitrogen. what actually are the benefits of using nitro instead of regular compressed air sa tires . magkano ang magpalagay ng nitro for 4 tires.
February 23rd, 2011 08:30 PM #934
Sir Gin, mas ok po ang nitrogen specially sa malayuang biyahe.
50 pesos per tire ang singil... pag padagdag lang ng nitro 20 pesos per tire ata.
Additional info about nitrogen in servitek:
Benefits of inflation tires with nitrogen gas rather than compressed air.
-enjoy driving with more safety and comfort.
-reduce the possibility of tire blow out.
-reduce driving noise.
-increase the life of tires.
-cut down fuel consumption.
-great protection against oxidation for the rims.
-help environmental protection.
drive safely po.
- 52,731
February 23rd, 2011 08:54 PM #935
February 23rd, 2011 09:06 PM #936
- A tire that has been inflated with nitrogen will maintain 'air pressure' much better and for a slightly longer period of time, as compared to a tire that has been inflated with regular air. This is because nitrogen molecules are larger in size than oxygen molecules and therefore, are less likely to leak or escape through the tire valve.
- This indirectly, helps in bettering the fuel efficiency of the vehicle. This is because, insufficient air pressure in the car tire can have an adverse effect on its fuel consumption and resultant fuel efficiency. Nitrogen filled tires have better and more consistent 'air pressure' which consequently, aid the vehicle's fuel efficiency (even if it is by a small margin).
- Pure nitrogen is much drier than regular air (which contains water vapor). Depending on tire temperatures, the water vapor in the air undergoes changes in pressure, which results in varying tire pressures. This is not an issue in case of nitrogen filled tires.
- Oxygen and water vapor react with the insides of the car tire, i.e., with the rubber as well as the metal rims, and gradually lead to development and deposition of rust. This has an adverse effect on the longevity of the car tire. Nitrogen does not react with the car tire insides or with the rim, thereby enhancing the life of the car tire.
- Nitrogen is a gas that does not support combustion, therefore in case of an extremely overheated tire catching fire, nitrogen makes for much better safety than regular air (which contains oxygen that supports combustion).
- Filling nitrogen in tires also helps in keeping the insides of the tire cool, even at high speeds.
February 23rd, 2011 11:28 PM #937
mura lang pala ang nitro eh. but how can you be sure na nitro nga ang ikarga sa tires.
February 24th, 2011 03:01 AM #938
Good day mga ka innova. May kaibigan ako nagpalit ng gulong yokahoma size 15 mga 90% pa ang thread baka may interesado, nagpapatulong lang. Walang vulcanize, kung baka ok pa for spare or set. Text me nalang kung interested 09209633101.
Plano ko rin palitan ang stock tires and rims ng innova j, saan kaya magandang presyo mai-trade in.
GLD
- Feb 2011
- 3
February 24th, 2011 07:39 AM #939Good Morning po sa lahat
I'm planning on switching to HID, ask ko lang mga sirs ano po ba ang bulb type ng headlight and foglamp natin?
Thank you sa pagsagot. Proud Innova G owner here.
February 24th, 2011 08:42 AM #940
high idle RPM at engine start
