Page 611 of 662 FirstFirst ... 511561601607608609610611612613614615621661 ... LastLast
Results 12,201 to 12,220 of 13229
    #12201
    Quote Originally Posted by bossing47 View Post
    again sasabihin ko uli hahahaha... balewala naman yang waranty na yan... hanggat makakalusot sila ilulusot talga ng casa obligasyon nila... recently magpapawarranty nga ako ng actuator ahehehe...
    na post ko na ata ito earlier pero ikwento ko na lang uli ahehehe...
    yun na... na void na daw warranty kasi hindi daw ako nagpapa sevice sa kanila... 2 years pa lang edad ng unit ko eh di ba 3 years or 100k which ever comes 1st?
    sa pananaw ko lang, ala naman connection ang actuator ko sa pagpapa service sa labas(change oil etc..) para ma void ang warranty nila ah? di naman makina nasira sakin para me pag basehan sila...
    ala lang nai kwento ko lang na dito sa pinas magugulang ang casa... ahehehehe... puro pakabig...
    yeah that was not a good reason for Toyota
    does it show in writing that warranty will be voided if any repairs/maintenance outside of Toyota are made without their consent? if not, then you can sue them....
    #12202
    Quote Originally Posted by brenz View Post
    Sir, as per your request, hereunder is the installed hood insulation. Sa Truevalue sa Park Square ko binili yan kasi walang available sa Ace Hardware dito sa Greenbelt 5.
    Ganda naman ng kulay nito.
    Sep 2009
    #12203
    Quote Originally Posted by innoBOB[09JmtG] View Post
    just had my 10K pms at Toyota marikina
    5k petot.
    Sir, ano ba yung ginagawa sa 10km pms? Thanks!
    #12204
    Quote Originally Posted by ArrJay0712 View Post
    I think change oil and oil filter lang. Ganun lang ginawa sa D4d namin
    Oct 2005
    #12205
    hello mga sirs...i recently bought a second hand Innova G M/T (model 2006)kaso sira yung car lighter socket ( tama ba term ko?). pa-help naman po how to fix it without going to casa. wala rin kasi yung manual nung binili ko sya. hindi na mahanap ng seller.
    hope someone can help me.
    thanks in advance
    -bononoy
  6. #12206
    guys
    ano da best na touch up paint for innova thermalyte color?
    thanks!
    dami ko kasi small chip out paint
    salamat!!
  7. #12207
    change oil
    change oil filter
    change spark plugs for vvti
    madaming inspection
    free carwash - sa cubao kasi wala nito
    engine detailing
    etc
    Sep 2009
    #12208
    change oil
    change oil filter
    madaming inspection
    engine detailing
    etc
    Thanks sir!
    Ganito rin kaya sa Toyota North-Edsa? Has anyone tried having their 10km PMS there?
    How about yung paglalagay ng lubricants sa doors and other parts, kelangan na ba at this point?
    Jun 2008
    #12209
    Quote Originally Posted by Bononoy View Post
    thanks in advance
    -bononoy
    Check the fuse box under the steering column and look for the fuse where the cigarette lighter socket is connected. But as far as I can remember, the cigarette lighter socket is connected to the line that runs the stereo, clock, and center dashboard backlights for the knobs. Please correct me if I'm wrong.
  10. #12210
    ano bang pwedeng gamitin sa scratches sa bumper ng innova natin, ung plastic,
    rubbing compound pa din ba?
    Jul 2006
    #12211
    Ano po yng tamang tire pressure ng stock tires ng Innova G. I just got my Innova from the casa and nun pinacheck ko sa gas station yng tire pressure nasa 45. Di ba sobra yun? Tinignan ko sa manual nasa 33 pag unloaded and 36 pag loaded sa likod. Eto mukhang mas tama, pero medyo nalito lang ako at bakit 45 nilagay ng casa.
    Aug 2006
    #12212
    thanks in advance
    -bononoy
    If the engine is not running, make sure the key must be in "ACC" position.
    Di yan gagana pag di nakasusi sa "ACC".
    If the key was on ACC and still the cigarette lighter is not working, check the fuse.
    For Cigarette lighter fuse it located under the steering wheel column. Fuse no. 37 - 15Amperes.
    Aug 2006
    #12213
    Quote Originally Posted by crossedge View Post
    Sundin mo yung nasa manual.
    Pag galing ng casa talagang mataas ang air pressure dahil matagal yan nakaparada lang sa yard kaya tinitigasan nila ang air pressure. Problema pag deliver nila sa customer di nila itinatama ang air pressure.
  14. #12214
    up ko lang?
    ano recommended niyong rubbing compound for scratches sa plastic bumper natin?
    Aug 2006
    #12215
    up ko lang?
    Pag malalim na ang scratches, repaint na yan. Pag lumabas na yung black color ng bumper ibig sabihin niyan malalim na ang gasgas at kailangan na ire-paint.
    Kung mababaw at walang peeled off paint puede yung 3M rubbing compound na nasa sachet. Go light when rubbing as not to discolor and rub off the clear coat.
    Kung paint transfer lang from other car's paint, you can use kerosene to peel off transferred paint.
  16. #12216
    ^thanks mile
    anong brand maganda na rubbing compound?
    and anong maganda namang paint to use for thermalyte color?
    oks lang ba yung mga spRay paint nin cans? basta heat resistant?
    Jan 2010
    #12217
    Pwede po ba akong magtanong ulit? Ano po ba ang gamit na panglinis sa car pagnatuyuan ng tubig? ayaw kasi matanggal ang spot-spots nya,mula nung mag-uulan,hindi po agad napunasan so nung magdry na... ayun ang nangyari.,pero bago palang yung car 1 week old plang pwede na po ba i-wax agad yun? ano po ba magandang gamitin para maalis ang spots? Thank you po ulit in advance sa mga magrereply.
    May 2007
    #12218
    Quote Originally Posted by matet_me24 View Post
    try nyo po Meguiar's Cleaner Wax for the water marks... IMO, ok lang po na iwax kung bago ang kotse... hindi ang bagong repaint.
    Jan 2010
    #12219
    Thank you po Ma'am Liv.
    Oct 2009
    #12220
    sir is it worth it to buy 2nd hand Toyota Innova G D4D 2006 model worth 700k Mileage is below 30,000.
    ngdadalawang isip kac ako sir dahil sa D4D issues, sir patulong naman ako para maliwanagan ako.
    by the way sir i am from Davao City
Toyota Innova Owners & Discussions [ARCHIVED]
