Page 52 of 56 FirstFirst ... 242484950515253545556 LastLast
Results 511 to 520 of 560
    #511
    Am always inspecting my gas tank.
    So far, no sign whatsoever..
    #512
    Sneaky yan boss parang mga katoto naten dito sa tsikot [emoji23]
    Hopefully hindi mo ma encounter.
    Oct 2013
    #513
    How about the leak? You have it repaired? Or replace gas tank assembly?
    Mga first gen ang may problema talaga.
    I'm still waiting for mine to warp again and leak. Huwag naman na sana.
    Replaced filler cap and charcoal canister already.
    If you will ask me, it is the old filler cap lang dapat pinalitan mo.
    Jul 2015
    #514
    Quote Originally Posted by Mile2 View Post
    I would agree that there's a problem in gas tank design. Point of fuel leakage and metal breakage was consistent - it is always underneath the front gas tank support.
    Olus 1 here, replaced my fuel tank, replaced fuel tank lid cap, still popped, next i will drill a smll hole in my original lid cap so that negative pressure will not persist, problem is that i am not sure if it is safe.
    Oct 2013
    #515
    Can you post a pic of your new fuel tank lid cap?
    If it just the same as the old one, it will give no improvement.
    Dec 2014
    #516
    My cousin told me na advise sa kanya ng toyota after a long drive or paguwi sa bahay, buksan yung gas tank para sumingaw daw yung naipon na pressure then close it again. Parang nagbubukas ka lang ng bottle ng coke. Ganon din before you leave in the morning. Mejo hassle lang pero mas hassle kapag nagleak na yung gas tank. At kapag magfulltank wag daw yung sagad, automatic lang. Hope this helps.
    Oct 2013
    #517
    Yung unang gas tank lid cover ng innova na gas ang may issue, kasi di sya nagpapapasok ng hangin. Yung bago na lid ang gamit ko ngayun.
    #518
    Quote Originally Posted by vvti2.0 View Post
    Can you kindly post pictures of before and after bro for our common reference? TIA
    Jul 2015
    #519
    Cast no shadow,
    sir i did replace the gas tank assy 16k, fuel lid cover 1.5k, still negative pressure persisted, popping of gas tank everytime i twist open the cap lid, wooooshing sound after short drive. I need to replace the charcoal canister. Bnd aid solution - drilled a small hole into the cap and wala no more wooooshing sound , [popping is also gone.. Trying to post the pic but cn't do it. I drilled the original cp, i still use the new one when it rains or just after i parked.
    Oct 2013
    #520
    If you will notice sa toyodiy..
    77310A CAP ASSY, FUEL TANK
    77300-28010 (08/2004 - ) 1 $46.54
    77300-52030 (08/2008 - ) 1 $41.99
    OLD tank cap
    NEW tank cap
Toyota Innova Gas Tank woes
