Page 26 of 56 FirstFirst ... 1622232425262728293036 ... LastLast
Results 251 to 260 of 560
    Jun 2012
    #251
    Quote Originally Posted by spat View Post
    Curious lang. Pano malaman kung kailangan nang palitan ang charcoal canister?
    Sir spat..there are symtoms..like dent in the gas tank...abnormal air vacuum once u open your fuel cap..worst is gas tank leaking..smell of gas inside ur cabin..toyota says they check the canister every 40k kms run..pls have it checked with ur trusted mechanic..
    Jun 2012
    #252
    Quote Originally Posted by kristine123 View Post
    My Innova is now 71k Km... Buti na lang di ko pa naranasan ang ganitong problema. Matagal ko na sinasabi itong problema sa SA. Kaso lang always naman sinasabi sa akin na wala daw problema. I cannot make noise of the problem kasi every time pumupunta ako sa CASA wala akong naririnig complaint about the Gas tank. I'm in the province kasi. Balitaan mo na lang kami sir about solving the problem...
    Ma'am sure thing..i am going fix the gas tank..and the canister muna..and hopefully they would hear us..
    Aug 2011
    #253
    Quote Originally Posted by nicnoc View Post
    Ok thanks for the info boss.
    #254
    In our manual,- nasa maintenance schedule ba na i-check ang canister every 40KKm?...
    16.3K:shower:
    #255
    Quote Originally Posted by Mile2 View Post
    It would only take 4-6 months for the first small dent to appear beneath the front strap support, then the dent would grew big in a matter of week and would leak after a month. This is from my experience on the 2nd warped gas tank. (same scenario, only the gas gas tank was replaced on my 1st warped gas tank problem).
    Bro.,- is the 'dent' directly underneath the front strap? How would you recognize it then? ...
    Or, is it in the gas tank overhang? Or, the other side of the strap?
    TIA.
    16.3K:shower:
    Aug 2006
    #256
    TIA.
    16.3K:shower:
    Yes it a huge dent just beneath the vicinity of front strap. if anyone has this problem, it is truly visible.
    Normally flat yung ilalim ng gas tank natin at mayroong lang mababaw na kanal para sa gas tank strap na may rubber insulator. Yung dent madalas makikita malapit sa kanto ng kanal para sa front gas tank strap.
    Aug 2006
    #257
    Quote Originally Posted by teiyaki boy View Post
    sorry OT
    toyota pasig is a different company from toyota cubao. what's under the same management as toyota cubao is manila bay, dasmarinas and marikina
    Sorry about the mixed up. It should be Toyota Marikina and Toyota Cubao tandem.
    Aug 2006
    #258
    16.3K:shower:
    Wala sa Owner's manual at wala din sa mga recommended maintenance during my previous PMS with casa. I have stressed this point on my gas tank warranty claim letter.
    #259
    Unserviceable kasi yun lintek na charcoal canister na yun. in short DISPOSABLE!
    #260
    Tumpak! same spot on my gas tank.
Toyota Innova Gas Tank woes
