Results 11 to 17 of 17
Unregistered user
- Jun 2003
- 1,122
August 8th, 2003 10:04 PM #11change your hi lux to a strada
well naobserve ko sa hilux is pag fully loaded sya less ang tagtag nya try putting sacks of sand at your cargo bed
but i think it may affect your fuel economy although minimal
kahit naman not loaded ok lang afterall you cant expect car like ride from a pick up
August 8th, 2003 11:06 PM #12
the harshness will be the same but the bounce will surely differ, how the suspension handles potholes and humps will also differ.
- 342
August 8th, 2003 11:53 PM #13palitan m gulong m yung stock na gulong medyo matagtag i change it to dunlop sp rv tires di na masyado tagtag malambot na sya mine is a 2000 model.
- Jan 1970
- 77
August 12th, 2003 12:02 AM #14tire pressure down to 30psi depending on your tire size, i use 32x10x15 duelers, it helps, pero talagang ganyan yan leaf springs kasi.
- 99
August 12th, 2003 02:23 PM #16Originally posted by OTEP
Baligtarin mo yung overload spring lang. It's the least used of all the springs unless pang-hakot talaga yung hilux mo. Usually ito yung nasa bottom ng spring pack.
Lower your tire pressure to around 32 psi din.
i agree mapapnsin mo diff ng binaigtad na overload spring. kaya lang bababa ang load limit mo.
Xiaomi E-Car
