Page 4 of 50 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 2021
    Oct 2005
    "The all-new 2KD-FTV four-cylinder diesel engine delivers top class fuel efficiency with extended maintenance periods. This latest technology diesel engine from Toyota has a high-pressure common rail direct fuel injection system and is fitted with a compact, high efficiency turbo charger. A range of electronic controls, including a drive-by-wire throttle system, assist in optimising engine power output, fuel efficiency, and emissions. The advanced controls also contribute to lower combustion noise and improved torque at low engine speeds."
    Excerpt from a D4D review. So, this is all crap? Is anyone aware of same problems with D4D-equipped HiLux? Do they have same problems, too?
    Jul 2005
    larshell, number 15 ka sa mga nagreklamo sa dealer mo? medyo alarming ang bilang considering maraming dealers ang toyota. multiply 15 by the number of dealers eh hindi biro yun. hay naku. my diesel adventure has 90k kms sa odo and not once pumalya ito. i know toyota has a 100k kms/3 year warranty on their engines. i appreciate the engine warranty, ayoko lang ng abala. that's why i'm purchasing a new car dahil ayoko ng frequent maintenance.
    Dec 2003
    i think its not the engine itself, but the fuel system
    Oct 2005
    Mga Innova peeps..
    My INNOVA G Diesel Variant was brought by my brother a while ago at Marikina
    Service Station. My 15k PMS was also done at the said service station. Prior
    to
    the 15K PMS, we already have complaints that after several full tanks of
    diesel
    fuel from PETRON and mixing it with ESTROL Biodiesel (5% and 1%), the engine
    begins to experience the following:
    1. The engine often dies after starting it. This is true during cold startup
    (mornings and after several hours of being parked). This is sometimes called
    by
    users - pumapalya o na-chochoke. Kelanagn mo apakan yung gas pedal or rev up.
    the engine.
    2. Sometimes during shifting gears, especially on slow speed (2nd gear) parang
    kakadyot ung makina o malulunod (has the tendency to stop) pag hindi mo agad
    inapakan ung gas pedal.
    3. Sometimes, I feel that the engine is loosing power. Although my top speed
    is
    not affected, the behavior of the engine sa arangkadahan or during normal
    speed
    is not the same. sometimes I do need to drive hard. But I observed that my
    fuel
    consumption is still the same. 9.5-10.5 KM/L pa rin. I am now using Shell
    Diesel.
    All of these symptoms were relayed by my brother sa toyota mechanic sa
    Marikina.
    Toyota diagnosed again our unit by using their laptop to get into the unit's
    engine statistics. My brother also relayed the possibility of the fuel filter
    being clogged and maybe it just need to be adjusted. However, toyota did not
    attempt to take a look. They are satisfied with the results being shown by the
    engine at their laptop. The other bad news is, they still have to report the
    said event either at planta or at Cubao. They instructed my brother that they
    will contact us again for the next visit. This time at cubao. I am planning to
    bring my unit at P. Tamo or Makati this Saturday for a second opinion. These
    stations I believe are independent and have their own pool of expert mechanics
    and management that can decide immediately and do not depend on other
    stations.
    Since I am not the only one who have experienced such behavior, (others are
    just using pure diesel without additives or biodiesel) maybe we could organize
    a body or at least help each other to get the attention of Toyota. I believe
    that the D4d engine is not that bad since it has been released before in other
    countries. There might just be an adjustment with our engines. Lets push
    Toyota
    to work on this issue. Toyota must have a fixed for this issue, better yet
    fixed this issue so that our engine can use and benefit from biodiesel.
    Quote Originally Posted by lord
    Mga Innova peeps..
    to
    diesel
    by
    the engine.
    is
    speed
    fuel
    Diesel.
    Marikina.
    stations.
    Toyota
    Well that's not a good practise that pag start sa morning o pagmatagal syang naka park, kailangang rev up ang engine kaagad dahil nga sa namamatay sya. Dapat pa check mo sa Toyota thoroughly yang car mo dahil it will wear up your engine fast if you will continue doing it. Try mo kaya Seaoil " bioexceed" product nila. That's what my friend is using on his Sorento 2.5 CDRi and his ODO now is more than 9K at never pa syang nagka problem sa engine nya. He normally add 2 liters on his 80ltr tank.
    Apr 2003
    Quote Originally Posted by apexi_66
    Yup, I once read a motoring article that advises against revving your engine immediately after starting it coz the oil hasn't circulated yet.
    Feb 2005
    Try to stop using additives and see if performance will improve. Sensitive kasi sa pressure and injection pump system. Additives could have been affecting the consistency of the fuel. It can also affect the timing of the injectors causing a delay in delivery and thus loss of power.
    Mar 2005
    kung minsan mahirap din bumili kagad ng bagong technology, nagiging guinea pig ka pa.
    yep oldblue... parang v0.r0 syndrome of most softwares
    Jun 2005
    wala bang way para ma DIY manual filtering ang diesel? Para bumili na lang kayo sa container at idaan sa inyong sariling filtering before feeding it to your rig.
    D4D is not a very new Engine. It's been running for a few years already for other countries. Is it possible to check the performance of the D4D engines from other coutries as well? Like Thailand and Indonesia.
    Aug 2003
    jimaroquai:wala bang way para ma DIY manual filtering ang diesel? Para bumili na lang kayo sa container at idaan sa inyong sariling filtering before feeding it to your rig.
    hmmm...now that's an idea(for a tsikot article)...
    Dec 2003
    wow i dont know about you but manually filtering 60+ liters of diesel does not work for me and if you use your innova often...pwede kana magtrabaho sa gas station hehe
    Oct 2005
    It looks like we're still way too far from completing the three pillars of CLEAN DIESEL technology: (1) State-of-the-art engines, (2) cleaner burning fuels, (3) effective emmissions-control system. (Parang Centrino platform..hehe). Nasa step 1 pa lang tayo, if you'd consider the D4D as state-of-the-art. Clean Air Act? How far did the government really went on this? Just a legislation? Just a thought....
    Oct 2005
    Some excerpts:
    "Today's automobile diesel engine...is a high-tech juggernaut, markedly more sophisticated than the gasoline engine.''
    "Recent technology has made diesel engines more environmentally sound and the barrier is a psychological one more than a rational one."
    It looks like that the D4D is suffering from a case of engine technology which is not fully compatible with the diesel fuel technology available to phil. market.
    Dec 2004
    most of the countries used euro4 compliant diesel fuel which has 50 parts per million of sulfur, while the phil used only euro 2 compliant diesel which has 250ppm sulfur that's why its dirtier and clogging or choking the fuel system. My friend at UNIOIL told me that if they sell euro 4 compliant diesel which is used at other countries the price will be more expensive than premium unleaded gasoline
    Oct 2005
    Quote Originally Posted by cary168
    *cary168... thanks for the info. Clearly an ENGINE/FUEL MISMATCH. Cleaner diesels and cleaner fuels go hand-in-hand. Diesel technology is very promising, and it will be a big part of energy future. Europe is really way ahead on this...
    yup... that is true...
    our clean air act is only up to euro 1 and 2 (at best) compliant.
    this is just the same with our fellow SEA neighbors... around 500 ppm of sulfur for diesel. none of our neighbors have yet to implement a lower ppm figure (though they plan a 10ppm for 2010).
    this will entail huge refinery upgrades by the way.
    May 2005
    Quote Originally Posted by mazdamazda
    So ang D4d engine ba is Euro4 complaint? kapag euro4 naba ang engine wont much sa euro2 fuel?
    May 2005
    Quote Originally Posted by larshell
    Not quite sure if the D4D engine has been tested for EURO4 Compliance but for a vehicle to adhere to EURO4 Standards means that both the engine and the fuel quality must match. EURO4 measures emissions compliance(byproduct) and not hardware compliance. Some of the manufacturers advertise EURO4 compliance but if used with lower grade fuel then expect it to perform less that what is expected. Just my opinion bro
Toyota D4D engine woes
